Replace factory sub with other sub
Old Nov 22, 2010 | 07:14 PM
SneakyF350's Avatar
SneakyF350
Question Replace factory sub with other sub
Since they make the prefab boxes to fit the power slide rear window trucks now, I was thinking of replacing the factory sub, which doesn't seem to do much, with a set of 8s or 10s behind the rear seat.
Has anyone tried to utilze the factory sub speaker leads to run signal to an aftermarket amp?
Is it crossed over at the radio output to let out only the lows?
Old Nov 23, 2010 | 07:24 AM
ruschejj's Avatar
ruschejj
Signal to factory sub enclosure is not altered at the back of the head unit. If you take your back seats out and then take out the factory sub, you will see an amp attached to it.
I made my own enclosures to fit 2 10" subs behind the rear seats, used signal input for an amp from the rear door speakers. I did not use the factory sub feed.
Old Nov 23, 2010 | 07:58 AM
Scootimus's Avatar
Scootimus
Do you guys have any pics of you boxes in the truck? I currently don't have and enclosure and planning on making one. I'm looking for some design ideas.
Old Nov 23, 2010 | 09:49 AM
djjoshuad's Avatar
djjoshuad
Why didn't you use the factory sub feed? Also, do you have the rear underseat storage?
Old Nov 23, 2010 | 02:55 PM
ruschejj's Avatar
ruschejj
I will post some pics tomorrow. I did not use the factory sub feed because the factory sub sounded so **** poor I did not want any part of it. I used line level converters tied into the rear channels to make an RCA type plug feed into my amp.
FYI, there is a crossover at each speaker for the doors (just a little resistor soldered onto the mid range speaker). I junked this stuff too.
NorthGaExpediton
Nov 15, 2012 08:00 PM
Curt's05
Mar 21, 2012 01:46 AM
HotLap
Aug 16, 2005 12:48 PM
coolexplorer
13
Jul 17, 2003 11:25 AM
