Sponsored by: Innova
99 Explorer Stereo systen replacement help needed!
Old May 29, 2002 | 12:06 PM
devil421's Avatar
devil421
Im working on a plan to swap out the stock, premium stereo for something sweeter. I have the console cd changer, 4 speaker, stereo. It is not the Mach system as far as I know. Anyway, here's my plan.
Im partial to Pioneer for value and performance so Im sticking with them (I also plan on adding XM eventually). Prices from Crutchfield.
HU - Pioneer DEH-P4400 ($200)
Speakers - Four TS-A6867 6x8 ($200 total)
Changer - CDX-P1270 (12 CD) ($220)
Now, here's the tricky part. I do not know if my stereo has the factory amp in the rear? Where is it located inside the truck? With a better headunit and better speakers, do I still need to use the stock amp or am I better off without it (not really thinking about an aftermarket amp)? Any suggestions and/or info at all is appreciated!
Thanks
JDP
Old May 29, 2002 | 12:16 PM
CobraXP's Avatar
CobraXP
Your amp should be located behind the rear panel in the back of you X on the passenger side. If you are not planning on adding any amps when you change out the system, then you can use the factory amp and it will be fine. I would use the Metra adapters - makes it basically a plug-n-play install. Then you will not have to run any new speaker wires, etc. Just make sure to hook the power antennea to the harness so that the factory amp turns on. That is the way I did mine at the beginning also...
Old May 29, 2002 | 04:39 PM
John8172's Avatar
John8172
My suggestion is to spend an extra $100 on the HU and upgrade to the Pioneer 7400MP. I have it in my truck and it is without a doubt the best CD player I have ever had, let me tell you why...it has a High Pass Filter, allows you to filter different frequencies of bass to your speakers. I have the Kenwood 5x7's (no amp) and can turn the HPF on 80Hz and crank the volume to 50 and don't have to worry about the speakers distorting from bass. Don't be fooled by the 6400 model, it looks the same but does not have the HPF or play MP3's. The 7400MP plays MP3's, has a subwoofer control with a Low Pass Filter (only shows up if you have the remote hooked up to an amp). To say the least I am very impressed. As far as buying everything from Crutchfield...they are an excellent company but their prices aren't the best...just my opinion.
Old May 30, 2002 | 07:51 AM
devil421's Avatar
devil421
Then where would you suggest I purchase from? Keeping in mind that one of the big advantages of Crutchfield is their service and that they include most adapters and the like free of charge with your kit. Anywhere better to look?
Old May 30, 2002 | 10:34 AM
John8172's Avatar
John8172
First I would shop locally and see what is available, sometimes you can catch really good sales. But as we all know you can almost always find it cheaper on the internet. Check out the link below, it has a bunch of sites to browse through. I haven't been through all of them yet so I can't tell you which one is cheaper.
http://www.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=40;t=005906
Competitionsound.com sells them for $237, check them out.
http://www.competitionsound.com/competitiondirect/dehp7400mp.html
The best advise I can give when ordering online is to call the company first to make sure they have the product in stock and find out what their shipping policy is.
Hope this helps.
If you do get the 7400MP I guarantee you will not be disappointed!
John
Old May 30, 2002 | 11:20 AM
devil421's Avatar
devil421
I just did some research and sure enough, I could save about $150 on my system buying from other than Crutchfield. Now, if I were to buy the actual hardware without adapters and such included (as Crutchfield does), what all would I need? I decided to use the stock amp with the new unit so Im guessing I will need to following pieces:
1. HU install kit w/ amp integrator harness and regular harness
2. Ford speaker wire to Pioneer speaker adapters
3. HU, Speakers, Changer
Will I need the adapter for the antenna that I see on some websites?
Im a bit confused about the amp integration harness. Is this something that would plug in seperate from the regular speaker wire harness or does it plug in line with that harness? Its a little confusing and I dont want to buy the wrong thing.
Thanks
Old Jun 1, 2002 | 09:14 PM
Larry S's Avatar
Larry S
Starting with 1998 the Explorer without the Mach system has an amp integrated with the factory head unit thus no need to worry about an amp bypass. I put an Alpine 7892 in my 1998 Explorer as well as the Pioneer TS-A6895 speakers in the doors. Big improvement! Anyway I hope this helps...
Old Jun 3, 2002 | 07:52 AM
devil421's Avatar
devil421
Yes thats VERY helpful. Even Crutchfield said I have the extra amp in the rear. Glad I dont have to worry about it. Can't wait to get the new gear!
Old Jun 3, 2002 | 09:26 PM
Larry S's Avatar
Larry S
If you are going to replace the head unit Look at the Alpine 7892..it is very nice..also get the Scosche FD2 wiring kit...got mine at Walmat for about $6. I ordered a Scosche FD1300 install kit. It is very nice and has a pocket that is nearly one din in size. Many kits will only hold a CD. I ordered that kit from Sounddomain.com. Very inexpensive. Good luck
Old Jun 4, 2002 | 02:58 PM
n2racin's Avatar
n2racin
Hello. If you are changing all those components seems to my it would be a big plus to also change the factory amp.
Old Jun 4, 2002 | 03:20 PM
devil421's Avatar
devil421
Read the post by Larry 4 entries up. Sounds like there is no extra amp (I concur since I couldnt see where they would possibly put it!).
Old Jun 5, 2002 | 02:43 PM
devil421's Avatar
devil421
DEH-P440 instead of DEH-P4400. The specs on this unit indicate HPF and LPF which the 4400 does not list. Is that the same thing that you were talking about on the 7400MP model that helps with distortion?
If so, then Ill probably go with that model instead.
Thanks
Old Jun 6, 2002 | 09:44 AM
odinmurphy's Avatar
odinmurphy
silar
20
Mar 3, 2015 10:23 PM
Sullid01
Dec 17, 2012 06:34 AM
BadDogPSD
45
Apr 1, 2006 12:58 AM
elexpedition_99
Oct 18, 2005 02:26 PM
devil421
Apr 25, 2002 05:42 PM
