In frame oil pan replacement.
??? Apparently 5.0 ford f150 can get the oil pan replaced by jacking it up by the harmonic balancer, after removing mounts i think ?....
And a guy here just did his 99 f350 like this too !!!!!!
Is there a problem with doing this, I've never heard this before on FTE .....
I have done it on my f150. Almost could not get it high enough because the motor hit the fire wall. Have not done it on PSD (yet) But it appears it would need to go pretty high. I would try the balancer. But i think it would need to come forward and then up to get it nice and high to work on it. I might opt to use the "picker" the next time i do one. I want plenty of room under there to make sure everything is just so. My f150 was tough on space and i questioned everything was in place once done. Changed the oil pump also while it was off.
Dan
Dan
Don't cut a thing under there. Drill the rivets out to remove the crossmember, switch pan, replace crossmember, reinstall rivets (if you can't deal with the rivet thing them just use some high grade nuts and bolts. Two hour job... max.
Although the crossmember is not 'load bearing' (until side impact) it is still an integral part of the framework.
NO NO NO!!!
Ding Ding Ding... We have a winner!!!
The reason for pulling the motor is to allow the sealant to cure oil free... If you do it in frame, I hope you like oil leaks, because you will have one.
We cut and lengthen the main frame rails on 56,000 gvw trucks all the time, trucks that get used in all kinds of frame torsion situations in farm fields. I have seen destroyed rims and tires, broken springs, and broken axles, but I can't think of a single situation where a stretched frame has failed. I would have no concerns at all about cutting and welding the cross member. By all means if you are not an experienced welder, don't do it, but if you are a good welder it should be stronger than original.
I'll agree that cutting that sucker and tacking it back up would be the fastest and easiest way to change the oil pan. However, a beneficial way of going about it would be to remove the rivets and go back with bolts. With the crossmember as a 'bolt-in' it sure makes it easy to check the mains.
mytruckisolderthanme
03-23-2013 08:46 AM
Dufftrucks
11-21-2011 06:58 PM
