Over Boost Anhialator
Old Jun 6, 2008 | 11:54 PM
PSDiesel911's Avatar
PSDiesel911
I ordered an over boost anhialtor (spelling?) and it should be in the mail. Its supposed to stop the check engine light and the automatic action the computer takes when it senses too much boost from the turbo. Does anyone know where it actually goes?
Old Jun 7, 2008 | 12:50 AM
orng1's Avatar
orng1
I imagine it would go inline with the map sensor. More than likely it's where you put the boost gauge line from. Just keep the ECU from reading all the boost.
Old Jun 7, 2008 | 01:03 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
If you got it from Dennis at ITP then this will be the exact instructions. If you got a different version, you still will get the idea.
http://www.itpdiesel.com/other/Overb...structions.pdf
Old Jun 7, 2008 | 01:15 AM
rivrrunner's Avatar
rivrrunner
Rampage-350 got you covered....TIP, do not adjust the dial it is preset...
Old Jun 7, 2008 | 01:18 AM
Izzy351's Avatar
Izzy351
VERY easy install. Rivals the HPX as one of the easiest mods to put in.
Old Jun 7, 2008 | 11:10 AM
aklim's Avatar
aklim
It stops the overboost CEL and the defueling when too much boost (24 psi +) is detected. OTOH, it will do nothing if the CEL light is from lack of oil pressure. P1211 code
Old Jun 7, 2008 | 11:20 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Well that just saved me another post. I couldnt figure out why I was throwing the CEL was commingnon at 25 psi. I guess I have the Lack of Oil press light. Darn
Old Jun 7, 2008 | 12:33 PM
aklim's Avatar
aklim
I'm NOT saying that is your problem. You need a code scanner to tell. Chipped vehicles tend to have those issues. I had it with my 60HP Tow tune and I wasn't even at WOT.
Old Jun 7, 2008 | 12:45 PM
weekendwarriorfsw32
Master of Strokes
Well do you know any some what cheap Code reader that will read Diesels. I have always wanted on but they cost$$$$
Old Jun 7, 2008 | 12:51 PM
aklim's Avatar
aklim
Try Autozone. Sometimes they have a reader that will read your codes. I have an Auto X-Ray that will. If were were closer, I'd let you use it but I don't have that long a cable to reach you. eBay Motors: Auto Xray Diagnostic Scanner Chrysler XP240 (item 300231252255 end time Jun-12-08 20:34:44 PDT)
That one looks like mine. I'm not sure if it would work for you. I might have an old OBD II cable I can spare that will work if it were he same one.
bleeds blue
Apr 29, 2014 06:56 PM
grizzly11
21
Jan 11, 2011 09:51 PM
diesel-fitter-bum01
23
Dec 9, 2009 05:54 PM
deerejohngreen
13
Jun 28, 2009 07:12 PM
don77
Jan 24, 2009 03:35 PM
