Safe Boost Level
Old Jun 27, 2009 | 09:46 PM
deerejohngreen's Avatar
deerejohngreen
Safe Boost Level
What psi can be run on a 2001 7.3l without getting a over boost code?
Old Jun 27, 2009 | 09:49 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Welcome to the forum. You can get about 22-23psi to the sensor before it throws a code somewhere around 24ish. But that's all mine ever sees
Old Jun 27, 2009 | 10:02 PM
F350-6's Avatar
F350-6
Welcome to FTE. As Kris alluded to, the PCM will throw a code around 24 psi, but there are ways to make sure the PCM never sees more than 22 psi, even if your boosting over 30, or 40, or 50. But to do that repeatedly, you'll need to upgrade the turbo too.
Old Jun 27, 2009 | 10:05 PM
PowerstrokeJunkie
or 60 ..........
Old Jun 27, 2009 | 10:39 PM
orng1's Avatar
orng1
Wow 60, that must be an expensive turbo.
Old Jun 27, 2009 | 10:46 PM
PowerstrokeJunkie
No not really, cheaper than a 38r.
Old Jun 27, 2009 | 11:13 PM
Bigcat350's Avatar
Bigcat350
Chris Tell me a little about this turbo what does it fit on 7.3?
Old Jun 27, 2009 | 11:15 PM
Adam0331's Avatar
Adam0331
S400ish???
Old Jun 28, 2009 | 07:28 AM
HKusp's Avatar
HKusp
How long has your name been changed?
Old Jun 28, 2009 | 10:36 AM
deerejohngreen
I have a gauge that plugs into the map. How can I not let the PCM read more than 22 psi and still us my boost gauge?
Old Jun 28, 2009 | 10:41 AM
gasgrunt88's Avatar
gasgrunt88
You'll have to get an OBA, or OverBoost Annihilator or however you spell it. It replaces your MAP line so you could just move your boost fitting to the line on the OBA. Talk to Clay, he'll hook you up!
Old Jun 28, 2009 | 10:55 AM
Izzy351's Avatar
Izzy351
You can see my OBA (black **** on the left) and gauge line fitted into my Riff-Raff AIH delete plug (Thanks again Clay!!) here:
Old Jun 28, 2009 | 03:43 PM
PowerstrokeJunkie
Yes, S400, 75-76mm, same compressor as Swamps BFH, whatever you want to call it. It's 1/8" from the cylinder head, and rubbed on the wiper cowl to the point where i had to get the BFH out to make some space..
Old Jun 28, 2009 | 07:12 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
Here's my OBA. Part's from an air compressor. (post #9)
https://www.ford-trucks.com/forums/8...a-on-ebay.html
64ponton
Dec 5, 2007 08:47 PM
Chance_Thomas
Apr 24, 2007 03:10 PM
mcbryant
May 15, 2003 05:49 PM
mcneal
Feb 15, 2001 06:50 PM
