Boost numbers???
Are you worried you're not getting enough boost? Check to make sure all your intercooler boots are sealed up tight and check your up-pipes for leaks.
Bought a boost fooler and actually lost 11lbs of boost. Arguing with the guy now about it. He says it's not possible, so I guess my gauge is lying to me. HA! Would just like to run around 30-40lbs, I think it would compliment my other ad-ons. Oh and the bigger turbo is in the works,but I need other stuff first.
I will check it out and get back to ya,just think it would run etter if it didn't top out at 24lbs of boost. Have a WW and trying to get this boost fooler worked out. With all he toys I have in the garage ready to go on I should dyno at over 400HP. Can't wait until warmer climates!!
I have stock turbo and injectors, most importantly stock tune and I run a solid 19lb boost. The only thing is airraid dropin filter, 4" pipe instead of the ccv thing, and I cranked the wastegate actuator rod probly 2 turns.
I have new couplers and stuff holdng it all in as well as new uppipe donuts.
Check for leaks. I ruined a turbo because of it. Learn from me.
I also want 40 psi. I'd love to have a transmission that can hold up to that boost as well.
