looking for more boost
Old Jan 7, 2011 | 09:40 PM
grizzly11's Avatar
grizzly11
Im looking for more boost. Im all stock besides exghast and over boost kit. I have heard of doing something with the wastegate rod, can anyone shed some light on the situation.
Old Jan 7, 2011 | 09:59 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
What boost do you see now?
Old Jan 8, 2011 | 08:00 AM
grizzly11's Avatar
grizzly11
Clay I got aih delete plug and its awesome. I can touch 10psi if its right to the floor board but we got a bunch of snow last night so no dry pavement this truck just don't seam to have the get up n go like my 96 did but that was 2wd and reg cab
Old Jan 8, 2011 | 08:08 AM
bdrummonds's Avatar
bdrummonds
if you can only see 10 psi max, then that means you have a boost leak somewhere. Untuned, these trucks will see up to 18psi, with custom tuning up to 30psi. I would start checking all your intake system boots for leaks, check your MAP line from the spyder to the MAP sensor, also look at up-pipes for signs of exhaust leakage.
Old Jan 8, 2011 | 08:13 AM
Kwikkordead's Avatar
Kwikkordead
Yeah, 10 psi is too low unless you are below 2000 rpm.
You won't be able to build much boost on stock tune until you hit 2500.
Old Jan 8, 2011 | 05:45 PM
Riffraff Diesel
PREMIUM SPONSOR
Have you checked to make sure your MAP line is connected? Did you have the issue before the OBA?
Old Jan 8, 2011 | 08:55 PM
grizzly11's Avatar
grizzly11
i will check on the leaks. Would being in park be a way to watch guage or should the motor be under load when i check.
Old Jan 8, 2011 | 09:07 PM
jeronlines's Avatar
jeronlines
Not to hijack, but you're talking boost on a stock tune, so what should be be seeing say at 55% throttle position w/ 3000 rpm? Or 70% throttle, 2500 rpm?
Old Jan 8, 2011 | 09:17 PM
HD Rider's Avatar
HD Rider
You need to be under load to build boost.
Old Jan 8, 2011 | 09:18 PM
grizzly11's Avatar
grizzly11
i guess i dont really understand what you are trying to say. I dont have a chip or programmer so this all stock i dont know how to post pics but i wouldnt mind taking a pic of what i think is the over boost kit.
Old Jan 8, 2011 | 09:29 PM
jeronlines's Avatar
jeronlines
Upload the pics to an album (created in your user profile). In the album, click on a pic and then below the pic are two lines of code- "Picture URL" and "BB Code." Cut and paste the BB code one into a reply. Viola! Pic in your post.
Old Jan 9, 2011 | 10:17 PM
grizzly11's Avatar
grizzly11
I will get a pic up tomarrow
Old Jan 10, 2011 | 08:10 PM
grizzly11's Avatar
grizzly11
here is what i think is the over boost thing
Old Jan 10, 2011 | 08:33 PM
megawatt00's Avatar
megawatt00
That is an over boost annihilator of the home brew type. It is used to limit the map sensor from seeing more that 22ish psi of boost. That is when the PCM commands the truck to defuel.
Old Jan 10, 2011 | 09:55 PM
grizzly11's Avatar
grizzly11
Is it a homemade version?
