Intercooler install
Old May 23, 2008 | 05:03 PM
Flea's Avatar
Flea
Intercooler install
I am going to install an orig. 7.3L intercooler on my '97. It comes with the pipes and boots on each end of the pipes. How will this fit up to my y pipe and the turbo?
Will I need to get a special adapter?
Old May 23, 2008 | 05:30 PM
tjbeggs's Avatar
tjbeggs
is it a cooler from a Superduty? If so you will need custom built pipes
Old May 23, 2008 | 06:08 PM
FARM69's Avatar
FARM69
Yep, intercooler pipes need a little tweaking. If you have a mig/tig welder and a chop saw its pretty easy.
As for the intake spyder, I believe Ford is making the early 99 ones again.
Old May 23, 2008 | 06:28 PM
Flea's Avatar
Flea
I am okay with a mig welder but prefer to buy prefab. for this project. Where and how much for adapters?
How much was the spyder intake?
Old May 23, 2008 | 06:33 PM
tjbeggs's Avatar
tjbeggs
$580 for the Banks setup
Banks Twin Ram and Intercooler Pipes - 25970-X
Other than GTS (would recommend them, not even sure they are still in business) Banks is about all your going to find prefab. I found the pipes to be the easiest part of the whole project if that helps you any. The early 99 y-pipe is about $120 plus you need a turbo clamp ($30) and 2 boots and clamps (upwards of $50), unless you find on complete with all those parts on eBay but even then they go high at times.
blaze42069
Dec 28, 2008 12:21 PM
Bird Dog
Sep 3, 2007 12:06 PM
powerstroke1869
Aug 26, 2007 07:15 PM
painless
May 28, 2007 07:27 AM
ForemanES
30
Sep 22, 2006 07:27 PM
