no start.....
Old May 22, 2008 | 07:05 PM
  #31
MADVAN's Avatar
MADVAN
Really need a gauge in the oil system or a scan to see the IPR/ICP.
With the way it went on you my WAG is electrical or the IPR has the drain open. (stuck or bad o-ring)
Bill
Old May 22, 2008 | 07:11 PM
  #32
custom_nirvana's Avatar
custom_nirvana
I can find out the oil pressure. but thatll have to wait till tomorrow and im going to have work on getting it scaned.
  #33
Action4478's Avatar
Action4478
Originally Posted by WALJON
Is it normal for the HPOP resevoir to be empty after sitting?
No ... a bad injector O ring can cause both of the problems you have ,, no start & empty res.....
You can also pull the valve covers & watch for oil bubbling up from the base of an injector ( or two)....A guage will isolate which side to look at....
Old May 22, 2008 | 07:12 PM
  #34
Action4478's Avatar
Action4478
Bill
.......X 2.........A guage is cheaper then a dealer scan...
Old May 22, 2008 | 09:08 PM
  #35
MADVAN's Avatar
MADVAN
I did not see if you checked the IDM relay.
You know the PCM is up (WTS lamp), so exchange the relay with the IDM to see if you loose the PCM.
Bill
Old May 23, 2008 | 11:10 AM
  #36
custom_nirvana
Bill
how do i change the relays?
Old May 23, 2008 | 11:45 AM
  #37
Action4478's Avatar
Action4478
look ...here... pull the two relays & switch positions ...
Old May 23, 2008 | 12:01 PM
  #38
custom_nirvana
Not trying to to be a pain but i dont see a relay for the pcm......
Old May 23, 2008 | 12:23 PM
  #39
Action4478's Avatar
Action4478
Are you looking under the hood ?...(power distribution box)
Old May 23, 2008 | 12:25 PM
  #40
Action4478's Avatar
Action4478
Relay # 1...
Old May 23, 2008 | 12:28 PM
  #41
custom_nirvana
Ya thats what i figgured the system part threw me off. but i just switched then and nothing......
The hpop revs still has oil in it.
Old May 23, 2008 | 02:55 PM
  #42
custom_nirvana
Finally, Through a friend we have come across a ford mech. that is bring home a scanner, so he is going to be nice enough come by and scan it for me.
Now what all should i look for?
Old May 24, 2008 | 04:04 PM
  #43
custom_nirvana
ok got it scanned and it threw two codes....
P0603- nothing really
P1280-Low pressure ICP
So with a connection i got a new icp and plug for 50 bucks and put it all in and stilll nothing......
Now were waiting to see if this connection can make its way to my truck to check the oil pressures.
Old May 24, 2008 | 04:33 PM
  #44
MADVAN's Avatar
MADVAN
You can dead head the pump left side/right side.
One at a time. This will find a leak in one or the other head. (inj o-ring)
Also can pull the VC's and look around the inj's.
My WAG is still the IPR. It happened to suddon.
Could have blown an inj o-ring if you were out playing with the truck with the chip turned up.
Bill
nybronc
Aug 12, 2013 01:06 PM
msriverrat
May 14, 2013 08:02 AM
mh5500
Aug 11, 2009 02:44 PM
Dkanngiesser
Electrical Systems/Wiring
Dec 13, 2007 07:54 PM
Fordman Dunn
Sep 14, 2004 05:42 AM
