starting problems
Old Dec 11, 2007 | 09:08 AM
Dkanngiesser's Avatar
Dkanngiesser
starting problems
I have a 1986 Ford F-250 and when I first try to start the truck in the morning, the motor will turn over, but the engine will not start. If I pull the truck, it will start and then the rest of the day it will start just fine. Any ideas? Thanks.
Old Dec 11, 2007 | 01:34 PM
Franklin2's Avatar
Franklin2
Is it fuel injected or carbed? What engine?
Old Dec 13, 2007 | 06:13 PM
Dkanngiesser
Dave, It is a fuel injected 460.
Old Dec 13, 2007 | 07:54 PM
Franklin2's Avatar
Franklin2
What type of fuel injection? I have a feeling I might not be able to help since the 86 460 wasn't originally fuel injected. So it sounds like you have a custom job there.
One thing I would try though, is check for voltage on the coil with the key in run and start positions. It sounds like you may not have any voltage at the coil in the start position.
GORDEN1234
2009 - 2014 F150
Jan 20, 2015 10:20 AM
jordo993
26
May 30, 2011 02:30 PM
ozzy460
Dec 31, 2010 10:23 AM
palaka
Dec 9, 2009 11:55 AM
mikewalsh1
May 10, 2006 05:29 PM
