no start.....
Old May 21, 2008 | 08:49 AM
Action4478's Avatar
Action4478
Do you have access to a scanner ...If yes ,, scan ICP & IPR dc% IIRC,,,IPR dc% will continue to rise in no start if the IPR is stuck....
unpluuging the ICP connector can some times unstick the IPR (temporarily )
Also ,, what condition are the batteries in (new ,old?)...
Old May 21, 2008 | 10:49 AM
MADVAN's Avatar
MADVAN
Might even find the IPR nut is loose or fell off.
Bill
Old May 21, 2008 | 11:25 AM
Action4478's Avatar
Action4478
Bill
I always forget that one ....
Old May 21, 2008 | 11:49 AM
custom_nirvana's Avatar
custom_nirvana
where abouts is the IPR nut?
the batteries are older, still possible for it to trun over with a dead cell?
Old May 21, 2008 | 12:50 PM
Action4478's Avatar
Action4478
The nut is the last part on the end of the IPR ..Pic ...here...
Old May 21, 2008 | 03:05 PM
custom_nirvana
checked the IPR but the best i could, its still there and tight....... anyone with a scanner around centeral florida?
Old May 22, 2008 | 04:13 PM
custom_nirvana
New batteries in and nothing.
Anyone have any more ideas?
Im trying to get it scaned, ford wants 180 to scan it......
Old May 22, 2008 | 05:07 PM
WALJON's Avatar
WALJON
Originally Posted by custom_nirvana
what would cause the hpop resv. to be empty? bad hpop oil pump?
Yeah Why would it be empty and did you check it again ?
Old May 22, 2008 | 06:02 PM
Action4478's Avatar
Action4478
You can set up some mechanical guages & see if you have HP pressure ,,,
Old May 22, 2008 | 06:31 PM
MADVAN's Avatar
MADVAN
Rick
I would think its something simple.
Truck has run fine then all of the sudden a no start.
IPR wires? Ign sw? Your shure it has fuel?
Bill
Old May 22, 2008 | 06:50 PM
Action4478's Avatar
Action4478
How hard were you running before no start?
Old May 22, 2008 | 06:51 PM
custom_nirvana
It has fuel, but there no smoke.
The hpop revs. was empty when we checked it bout 12 hours of sitting, we filled it and still nothing.
Where do i test for HP pressure?
Old May 22, 2008 | 06:55 PM
  #28
WALJON's Avatar
WALJON
Is it normal for the HPOP resevoir to be empty after sitting?
Old May 22, 2008 | 07:00 PM
  #29
Action4478's Avatar
Action4478
Have you unplugged the ICP sensor & tried to start it?...
pressurising the rails ........here...
Old May 22, 2008 | 07:03 PM
  #30
custom_nirvana
Ya we tryed that and got nothing.
