the intercooler boots, do they go to the turbo? (the air intake for the turbo)
The IC tubes come out of the turbo from the intake side and go down to the IC, out of the IC and back up into the motor by the turbo. There are 4 boots on the IC tubes. One between the turbo and tube, one between the tube and IC, one on the other side of the IC and tube, and one between the tube and base of turbo.
The scanner is a actron cp9125. Its a little one, but it works. The engine was off and the key on.
I don't think that scanner will pull codes for our PSD's. Have you dried out all the electrical connections ? If you have been trying to start it for awhile charge up the batteries while you dry everything out.
Unplug the ICP and try to start it. If it is bad, it should start but not run good. Next check the IPR. There is a wire connection on it and a cheap gold nut on the back that has to be snug. Here is a picture to help you out.
pressure washing engine is overrated imho. been doing it for years with no ill affect. granted i dont stand over the electronics on full blast, but you get the drift. i think you have other issues. did you just buy the truck?
