What is a normal EGT reading while doing 70 MPH?
Old Apr 29, 2008 | 08:01 AM
Pocket's Avatar
Pocket
No chip, no mods and at about 2k rpm I'm at 350-400 degrees on flat road.
Your probe is in the downpipe, isn't it......
Old Apr 29, 2008 | 08:42 AM
UP_There's Avatar
UP_There
I was thinking the same thing Curtis......an EGT probe in the downpipe is on average 200-300 degrees lower temps, sorta mis-leading if you are reading typical EGT posts on here.
Old Apr 29, 2008 | 08:43 AM
mueckster's Avatar
mueckster
Originally Posted by strokin_it7.3
Yep i run around that, sometimes 900+.
I only see that kind of EGTs pulling my fifth wheel at 65 mph. Uusually under 700* empty @ 70 mph.
Old Apr 29, 2008 | 08:49 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I'm turning around 2100 rpm's at 70mph (70 on gps- speedometer says 73-74) and my egt's are around 600-650 degrees, at about 5 psi of boost.
Old Apr 29, 2008 | 09:05 AM
GEugeneS's Avatar
GEugeneS
I run in 700 to 800 with an Edge Evo on setting 1
Old Apr 29, 2008 | 09:12 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Originally Posted by Pocket
If it's completely flat ground and no wind (almost impossible around here), I'm turning around 2100 rpm's, hover around 600-650 degrees, and about 5 psi of boost.
But since it's Colorado, around Denver my EGT's range from 450-900 degrees while crusing a steady speed at 70 mph, boost between 3-12 psi. Up in the mountains on I-70, EGT's cruising at 70 range from 300-1000 degrees, and boost between 3-20 psi. That's just maintaining a steady speed. Got altitude?
I'm in the same boat as POCKET, since I live less than 20miles from Parker, CO.
What gears do you have? 2100RPMs @ 70MPH with 36" tires? I've got 3.73s with ~33" tires (255/85R16 Big O XTs) and figuring in the correction factor I'm right about 1950RPMs for an actual 70MPH. With 36's I'd think you be lower, unless you're running 4.10s or deeper?
P.S. - Gary (GEugeneS) that is one SWEET RIG!!! I'm actually looking at buying a 99 Dually in white right now..... must.... resist....can't afford double-PMS!!!
Old Apr 29, 2008 | 09:19 AM
Pocket's Avatar
Pocket
I'm running 4.30's in mine.
Old Apr 29, 2008 | 09:20 AM
Izzy351's Avatar
Izzy351
I run anywhere from 400-700 depending on outside temps, and whether or not I'm going up a hill. It's mostly flat around here though. On interstates in the summer, I'm right around 550-600 on flat stretches. In the winter, probably around 450-500, unless it's really cold out -- that's when I see low 400s. It climbs up depending on the length of the overpass/hill but those are average numbers for me here in North Texas. My probe is in the up-pipe.
Old May 4, 2008 | 02:22 AM
eodmule's Avatar
eodmule
You know, I haven't looked. The previous owner installed it so I guess I'll have to check it tomorrow. I thought it was a few inches back from the EBPV.
Old May 4, 2008 | 02:31 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
About 500-550 here and 4 psi of boost!
Old May 6, 2008 | 09:35 AM
GEugeneS's Avatar
GEugeneS
Brendan, Thanks for the compliment. I always liked the duallies. I still have my '91 F350 gasser and pulled my trailer with that for years. Building a 550 ci stroker for it and it needs to be repainted, but I'll get it done someday. No $ now.
Also when I bring the '02 back down to between 60 and 65 I run between 600 and 700 on the flats.
Old May 6, 2008 | 12:32 PM
BENG0924's Avatar
BENG0924
I run 600 - 700 cruisin at 70 mph
stuart olson
24
Apr 22, 2019 06:34 AM
CO Wapiti
Mar 16, 2017 08:39 AM
Steven Stocki
Dec 20, 2016 04:07 PM
redge Moore
Apr 20, 2016 08:11 AM
speakerfritz
6.4L Power Stroke Diesel
Jan 20, 2016 09:10 PM
