Fuel pump psi
Apr 19, 2016 | 01:35 PM
Fuel pump psi
What is normal psi
Apr 19, 2016 | 03:54 PM
Quote:
Originally Posted by
redge Moore
What is normal psi
At the shrader valve, I have read that 60-70psi is normal...
Apr 19, 2016 | 03:55 PM
You should have around 60 lbs at the Schrader valve while engine is running.
Apr 19, 2016 | 10:26 PM
not to disagree with Tom, but I think stock it will run just fine on 40-45 psi. preferred pressure is 55-60, but you may have to do the old BB mod to get that pressure out of the regulator
Apr 20, 2016 | 07:56 AM
What about cranking pressure? Just for future knowledge.
Apr 20, 2016 | 08:00 AM
I went checked mine to be able an answer this. With fuse 22 pulled(simulating a no start) I get 45psi
Apr 20, 2016 | 08:08 AM
Apr 20, 2016 | 08:11 AM
My '96 has always run at 50 psi. I've read this is normal for a nonCalifornia truck, but that trucks delivered in California run higher, maybe 60psi+, because of different injectors needed to satisfy the regulators there.
kweiss
Jun 8, 2021 07:52 AM
landstorm
Feb 28, 2011 03:01 PM
John M T
Aug 31, 2008 12:55 PM
anthony aiello
Aug 14, 2003 01:41 AM
brett_d
Jan 15, 2002 10:22 PM
