turn signals
Old Mar 15, 2017 | 11:11 AM
CO Wapiti's Avatar
CO Wapiti
turn signals
My turn signals sometimes work very rapid and sometimes they work at normal speed with no rhym or reason. Sometimes one turn signal works rapidly and the other at a normal speed. Is this normal? Am I missing some feature to them? Thank you
Old Mar 15, 2017 | 11:34 AM
gcooley's Avatar
gcooley
Do you have a burnt out bulb?
Old Mar 15, 2017 | 11:43 AM
Frantz's Avatar
Frantz
Sounds like maybe a loose connection somewhere. Sounds like a warranty claim, but of course, it'll have to happen at the dealership to get fixed.
Old Mar 15, 2017 | 11:51 AM
CO Wapiti's Avatar
CO Wapiti
The truck only has 138 miles on it so I havn't checked for a burned out bulb. It's weird, when I start the truck the signals are always rapid then after driving it for a while they will work at normal speed then sometimes go back to flashing very rapidly. My truck is at the dealer for a Fab Fours rear bumper and they said they would check it out. I'll post their results if they actually find out what's going on. I never have much faith in the dealer's mechanics. Maybe I should because it's beyond me.
Old Mar 15, 2017 | 12:21 PM
Blk04Snake's Avatar
Blk04Snake
My turn signals do this when my snowplow is on the truck. Do you have the LED lights? I'm thinking that body module programming has something to do with it.
Old Mar 15, 2017 | 12:59 PM
Top_Speed1's Avatar
Top_Speed1
Hyper-blinking is usually a case of a loss of unexpected voltage drop or amperage draw on a circuit (CANbus sensing). So a bulb going out is a popular one yes, also some peeps have tried to upgrade to LED bulbs in their incandescent light sockets which will also cause the hyperblinking. BUT, with our all LED vehicle (minus vanity lights), I can't see this as an issue.
I agree, off to the dealer sir, u shall go.
Old Mar 15, 2017 | 03:00 PM
CO Wapiti's Avatar
CO Wapiti
I added an LED light bar but it hyper blinked since day one and it does it whether the light bar is on or not and it does it intermitently. Hopefully the dealer can figure it out.
Old Mar 15, 2017 | 04:18 PM
CO Wapiti's Avatar
CO Wapiti
I had the dealer install Fab Fours winch bumper installed that has extra turn signal lights within the bumper. Apperantely Ford's system is touchy because the change in electrical resistance in the system makes the turn signals hyper flash. They told me that Ford just came out with a bulliten to fix this problematic situation. I sure hope so!
Old Mar 15, 2017 | 04:24 PM
Frantz's Avatar
Frantz
Yep! I didn't realize you had changed it from stock. Ford's even having some issues with factory pick up deletes flashing too quickly, that's why I thought maybe you had a bad connection with the bed or something. Aftermarket stuff that has more lights is definitely the problem.
Old Mar 16, 2017 | 08:39 AM
CO Wapiti's Avatar
CO Wapiti
FYI, My dealer did the flash per Ford's bulletin and the turn signals work fine now. The mechanic said that I could now run LED lights if I wish with no problems (I have an XLT trim level).
lexustbs
6.7L Power Stroke Diesel
Jan 26, 2011 11:07 AM
daveshomeservice
2009 - 2014 F150
Nov 8, 2010 07:42 PM
qman
13
Mar 12, 2009 10:50 AM
afonda
22
Dec 20, 2008 01:47 PM
150ex
Mar 15, 2004 08:31 AM
