Thermostat
Old Apr 25, 2008 | 08:45 PM
PeeVee's Avatar
PeeVee
Thermostat
Has anyone had trouble removing the three small flanged bolts that hold the thermostat? Mine have never been touched from new (1994). My local garage didn't want to do it for fear of breaking them. I wanted them to install a hotter thermostat (205 deg) but they effectively said the existing one (stock 192) is good enough.
Old Apr 25, 2008 | 08:53 PM
FARM69's Avatar
FARM69
The PSD runs better with a 203 stat in it. I replaced mine a couple months ago and had some problems. I broke the the head off of one bolt. I just drilled out the bolt, tapped and dyed another bolt to fit.
About a month after I did that my waterpump went up and I got the original housing back.
The 203 stat can only be found here for our trucks. The ones you buy at the parts house are not the correct ones.
DIESELSITE 203* Thermostat
Old Apr 25, 2008 | 09:21 PM
Suber's Avatar
Suber
Farm is 100% right on the bolts. I too snapped a bolt on the t-stat flange, but it was due to torqing them too many times. If you re-use the ones that are in there, make sure that you get a good bead of RTS on the neck and seal it right the first time, then you wont have to worry about redoing it.
Old Apr 25, 2008 | 10:06 PM
spazinweasel's Avatar
spazinweasel
i am assuming his is a 94 dont that mean hes already got a 203? "Until 1996, all 7.3L Powerstrokes that were manufactured used an International water pump and an International short stem 203o thermostat . In 1996, Ford changed to a lower degree 195o"
Old Apr 26, 2008 | 08:18 AM
ltfox's Avatar
ltfox
Your right, 94 and 95's came stock with a 205* stat. Its only a upgrade for the 96 and 97's to get a 203* stat from diesel site.
Old Apr 26, 2008 | 10:29 AM
PeeVee's Avatar
PeeVee
Thermostat
I got my thermostat from NAPA. They said it was for a '95. But it sounds like it's no different to what I've already got. The part no. is 371-203 so it might be 203 deg after all. I also went to the local Ford dealer and they said theirs is 192! I'm having trouble staying warm in the winter - even when using grill inserts. The needle on the idiot gauge shows it's operating in the normal range but only just - it barely moves off the pin. I do get heat so the thermo is working. Maybe this is just the nature of the beast. My engine is the earliest PSD. When I bought the truck I paid $500 extra to get the new engine.
Old Apr 26, 2008 | 10:51 AM
tjbeggs's Avatar
tjbeggs
Yes you have the right stat for your truck. Ford has now changed all their stats to a 192. thats too cold! you want the 203 in there. Bolts might break and they might not. But if they ahve never been off then that means your water pump has never been changed either. How many miles on the truck?
Old Apr 26, 2008 | 11:42 AM
FARM69's Avatar
FARM69
Remember those stock gauges are basically idoit lights. Also, check of the condition of your thermostat neck. Sometimes they get pitted/rusty so I might be a good idea to replace it too.
Old Apr 26, 2008 | 11:47 AM
kawa's Avatar
kawa
If you do decide to change the Thermostat spray some "PB Blaster" on the screws. The housing forms a little lip all around the base of the housing and fill it up and let the screws soak for a couple of days.
Use a 6pt. socket and use steady constant pressure on the screws until they break free. They will sound like a gun shot. It's important to keep the socket, extension and breaker bar STRAIGHT.
Use a big breaker bar. (I use 1/4" stuff adapted to 1/2") it's easier to maintain the position and pressure. Use anti seize when replacing them.
Rog
Old Apr 26, 2008 | 02:45 PM
spazinweasel
just makin sure in case i have to do it!! thanks
Old Apr 26, 2008 | 03:36 PM
tjbeggs's Avatar
tjbeggs
another good tip is to take a long punch or even long extension and put it right on top of the bolt than smack it with a hammer. once or twice. that shocks it a bit and breaks things loose a little. Doesn't always work but helps.
Old Apr 26, 2008 | 06:06 PM
PeeVee's Avatar
PeeVee
Thermostat
Thanks everyone for your comments. Mileage on my truck is 215000 km. So it looks like I've already got the 203 thermo. then, and it's working. Probably best to leave it alone.
Old Apr 26, 2008 | 06:15 PM
tjbeggs's Avatar
tjbeggs
if its never been changed chances are its not working. If you are having trouble getting heat in the cab or engine operating hot enough its not working. probably stuck partly open.
I run 200 degrees no matter how cold it is unless I am idling.
Old Apr 26, 2008 | 11:02 PM
PeeVee's Avatar
PeeVee
Quite right. I suspect it's not operating 100%. I'll change it out after all, using all the advice kindly offered.
DHamSTER
Feb 4, 2014 11:07 AM
JaySVX
Mar 7, 2013 11:24 AM
grimace71
May 9, 2007 09:45 PM
Avanti
Jun 9, 2004 10:21 AM
elstx
Sep 16, 2003 09:46 PM
