need help chip install gone wrong
Old Apr 28, 2008 | 01:38 PM
  #46
jhand124's Avatar
jhand124
Congrats on the fix. So is the new PCM still an E99? If not your cruise light should work now.
Old Apr 28, 2008 | 01:45 PM
  #47
SOB Racing's Avatar
SOB Racing
If you have not had any luck by this time pull every fuse under the dash and check for any blown fuses. I had a similar situation and a 10 amp fuel pump fuse was blown. Also ckeck your relays
Old Apr 28, 2008 | 02:19 PM
  #48
bigtimebubba's Avatar
bigtimebubba
I'm not sure on the year for the pcm. It is a xle4 that was reflashed to the xle8 code. The truck does idle and run better now though, so I think the updated pcm was a good move after all of this
Old Apr 28, 2008 | 02:29 PM
  #49
ron's power stroke's Avatar
ron's power stroke
all the xle codes are for the early birds...i want/need one for a 99.5-01 truck if any one has a spare ..i want the better trans shift so jody can lock and unlock at a lower speed,,
Old Apr 28, 2008 | 03:57 PM
  #50
PaysonPSD's Avatar
PaysonPSD
Ron,
Does this mean that the later PCM is not just new software but also new hardware as well?
Old Apr 28, 2008 | 04:04 PM
  #51
Izzy351's Avatar
Izzy351
Originally Posted by bigtimebubba
Okay So I got it up and running today.
My original pcm was a vdh something but the pcm I bought is a xle8.
///SNIP///
Bubba
The VDH2 is from an '02 (that's what I have). '01s have PMT2. I think the only one newer than mine is the one in the '03s (VDH5 or similar). It sounds like you already had a newer PCM -- someone has been screwing with it...
Congrats on getting it back up & running!!
Old Apr 28, 2008 | 04:32 PM
  #52
ron's power stroke
Originally Posted by PaysonPSD
Ron,
not sure what the diffs are..just know a lot of guy's i talk to on another site for the early bird truck said it makes the truck run better..not more power..but just run better..i asked jody about my shifts..he said the 99.5 to 00 PCM he can make it run better and program the shifts a lot better..that = better power to the ground...i was the second xle program Jody made with the new tuning for XLE..i have plenty of power...i just want a smother running truck and a little better shifts...99.5 -00 is what Jody said..so thats what im looking for..
Old Apr 29, 2008 | 10:36 AM
  #53
PaysonPSD's Avatar
PaysonPSD
Thanks Ron. I am waiting for a call back from Jody and will ask him if an update reflash will bring an XLE up to a 99.5 level. Will post answer.
Edit: Talked to Diane & Jody. XLE not upgradeable. It is a 402 Code, must be 422 Code to upgrade. Jody said his best tunes are to a PMT1.
Old Apr 29, 2008 | 11:33 AM
  #54
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thats what I have. PMT-1. I wonder why Jody said that? I wonder what makes this one better?
Old Apr 29, 2008 | 01:02 PM
  #55
PaysonPSD's Avatar
PaysonPSD
Rick,
Actually that is what Diane told me. I'm not sure why. When I talk to one of them again I will ask. But she did say the PMT1
was for the newer stock turbos and injectors, as in 99.5 and up.
Old Apr 29, 2008 | 01:58 PM
  #56
ron's power stroke
thats just what he told me..i just couldnt explain why..
maybe its cause thats what he had the most practice with..PMT1 is the first real PCM...early99 has the xle..most got changes over to pmt1 in 99.5..just another down fall for modding the early bird and why alot of chips and tuners wont work....
Old Apr 29, 2008 | 05:41 PM
  #57
bigtimebubba
Okay so a new problem now. With the xle8 pcm if I don't baby the throttle the overdirve button will flash and it will shift hard. The trans temps go up also. I've read that it is in like a limp mode. The rpms have to be high for the truck to shift. If I shut the truck off and then start it back up and baby it it will shift some what somooth but if I get on the throttle it reverts back. It stays in this mode until I shut the truck off again.
Is there a way to have the pcm reflashed or do I need another pcm now. I might just try to buy a vdh5 like what was in there and be done with it.
Old Apr 29, 2008 | 05:45 PM
  #58
ron's power stroke
ether way its going to cost you..dealer can flash it..or jody at DP Tuner may be able to..and with a little extra power if you want it..but i would toss it and get another newer PCM like i said in my last post.....
Old Apr 30, 2008 | 11:11 AM
  #59
miller_feed
Rick,
Thanks Robin, I thought you meant that pcm itself was the best for his tunes. I wonder how many different PCMs there is from 99.5 to 03' there is? Does anyone know this?
Old Apr 30, 2008 | 11:34 AM
  #60
PaysonPSD's Avatar
PaysonPSD
I took it to mean that his best tunes are to the PMT1. Most likely for the reason Ron stated, he has the most experience with that particular PCM.
I talked to Jody yesterday about the tunes I want. The 80E with lock-up TC he cannot do right now because he sold the only XLE* he had to someone whose PCM got lost in the US Mail. He had a work around but said without the XLE* PCM it wouldn't be a true lock-up. So I told him I would send my XLE4 to him to do the tunes and that it what I'm going to do. The truck will be down for awhile but its not my daily driver and this way when I get it back the contacts will be all cleaned and the DP Tuner will have been tested to my pcm. Works for me. In the mean time I am trying to find a PMT1 for when I go to single shots.
