Rear Washer squirting onto passenger-floor?
In testing out my rear wiper and washer, I would hear a gurgling from under the dash on the passenger-side, and no water would come out the rear washer.
Felt on the floor, and it's wet with washer-fluid right up against the kick-panel.
Before I go digging for the connector that has come loose or the hose that is broken, as anyone experienced this in your X, and if so, where precisely should I be looking for the fix?
Bob,
The issue is a simple one for the Ex.
If you peel back the carpet from the outside top corner of the passenger floor board...you will see a rubber elbow going thru the floor and a plastic hose...close examination of yours and I'll bet they are not mated...
I've had to reconnect mine 2 or 3 times now...
Take a look...I bet you will find your issue.
I haven't zip tied mine yet...I figure I KNOW where this pressure relief point is and it is easy to fix...if I zip tie it...the next pop off may not be so easy a fix!!!
Good luck,
joe.
Good luck,
joe.
