Sponsored by: Real Truck
Thrust washer
Old Nov 5, 2010 | 04:28 PM
Golden's Avatar
Golden
Thrust washer
Hello all
After hearing some noises this morning coming from the front end of my truck. I decided to check all the bearings. I followed this post https://www.ford-trucks.com/forums/3...ll-joints.html to remove the axle's on both sides. On the Drivers side after I pulled the snap ring out I then proceeded to pull 3 round washers and 1 hex washer but on the passenger side i only pulled out 2 round washers and 1 hex washer. Is that right or am I missing one round washer on the passenger side?
Old Nov 5, 2010 | 05:55 PM
khxor's Avatar
khxor
The hex is sandwiched between 2 round washers, so you have an extra one on the drivers side.
Old Nov 5, 2010 | 06:55 PM
Golden's Avatar
Golden
Thanks Khxor
I wish i would have done the axle replacment 3 years ago myself instead of having a shop do it. That is probably why i am having problems now.
So i went back outside after i posted just to make sure and it turns out I only had one round washer on the passenger side not two.
Mike G
JWA
May 6, 2021 03:18 AM
DanielT28
17
Feb 28, 2015 06:05 PM
scottlane
Sep 30, 2009 10:43 PM
codyingersoll123
32
Feb 28, 2009 05:31 PM
