Rear Washer squirting onto passenger-floor?
In testing out my rear wiper and washer, I would hear a gurgling from under the dash on the passenger-side, and no water would come out the rear washer.
Felt on the floor, and it's wet with washer-fluid right up against the kick-panel. :-X18 Before I go digging for the connector that has come loose or the hose that is broken, as anyone experienced this in your X, and if so, where precisely should I be looking for the fix? |
Bob,
The issue is a simple one for the Ex. If you peel back the carpet from the outside top corner of the passenger floor board...you will see a rubber elbow going thru the floor and a plastic hose...close examination of yours and I'll bet they are not mated... I've had to reconnect mine 2 or 3 times now... Take a look...I bet you will find your issue. I haven't zip tied mine yet...I figure I KNOW where this pressure relief point is and it is easy to fix...if I zip tie it...the next pop off may not be so easy a fix!!! :-jammin Good luck, joe. |
Thanks! That is EXACTLY where the problem was!
This place rocks! :-headbang |
