Replacing Crank Sensor on 5.4 L
Old Apr 16, 2008 | 09:35 AM
eallanboggs's Avatar
eallanboggs
Has anyone replaced the crank sensor on the 5.4 liter V8? If so, does the A/C compressor have to be removed? Is there a procedure I can printout for this swap? The Haynes manual doesn't say much other than the A/C compressor might have to be replaced. This is a 2000 Expedition.
Old Apr 16, 2008 | 11:47 AM
Johnny Langton's Avatar
Johnny Langton
Remove belt.
Remove bolts on A/C compressor,and let it drop down a bit.
Remove single bolt on crank sensor,and remove.
Reverse order to button it up. No need to remove any A/C lines,etc.
JL
Old Apr 16, 2008 | 02:30 PM
eallanboggs
Thanks JL. That doesn't sound bad at all. Just glad I only have to move the A/C compressor out of the way rather than removing it which would require evacuating the system and then refilling it with R134. I'm doing this in hopes that it cures the random engine kills. Engine randomly shuts "OFF"(maybe once a week),but always immediately restarts. The owner says the dash lites and radio are still "ON" when this happens. The fuel pump, strainer and fuel filter have already been changed since the pressure at the schrader valve was 26lb. which is below the min., but it still shuts "OFF" from time to time.
Old Apr 16, 2008 | 06:30 PM
sbclemens's Avatar
sbclemens
If its intermittent, try cleaning the connector first. Mine had a couple of pounds of grime built up on it that once I cleaned it off the problem went away.
Old Apr 16, 2008 | 07:01 PM
eallanboggs
I would try that if it was my vehicle, but for under $20 I'm not going to chance a callback. I will clean the heck out of it with contact cleaner and compressed air though. Thanks for the suggestion.
Old Apr 16, 2008 | 08:04 PM
sbclemens's Avatar
sbclemens
Good point!
Old Feb 27, 2021 | 07:25 PM
Bgood36's Avatar
Bgood36
having somewhat the same issue with my 00 expedition..was wondering if you had a code for the crank sensor? A mechanic suggested replacing the cranksensor, but I don't have a code for the cranksensor. So maybe if there's a pound of grim on it, that's why it's acting up, and I don't have a code?
snorindad
Jul 23, 2019 08:27 PM
ExcursionXLTjordan
Nov 28, 2016 03:17 PM
michelle85
1997 - 2003 F150
Jan 18, 2011 09:46 AM
TommyR
Modular V10 (6.8l)
Feb 4, 2009 07:18 PM
eallanboggs
Apr 17, 2008 09:17 AM
