crank position sensor location
Old Nov 27, 2016 | 02:03 AM
ExcursionXLTjordan's Avatar
ExcursionXLTjordan
Hi,
I have done a google search and I have got no answer of where does the CPS located on my truck? Anyone have a good write-up?
knowing mine is 5.4 L 2000 model. 121,000 miles on clock.
Old Nov 27, 2016 | 08:22 AM
projectSHO89's Avatar
projectSHO89
The CKP sensor behind the AC compressor and its connector is commonly confused with the AC clutch coil.
You have to pull the compressor to get to the sensor.
Old Nov 27, 2016 | 07:21 PM
DSN46's Avatar
DSN46
There is enough play in the compressor lines to move it over and reach the CKP. I just did this on my V10 last month. Just take out the bolts holding the compressor in place and then slightly move it over and you can get to the single bolt holding the CKP in place. Disconnect the old and slide it out.... slide in new and reconnect.... put compressor back in place and replace bolts..... your done! Make sure you don't over-torque the compressor bolts! You can strip them out easily.
Doing this easy swap has brought me back up about 1 to 1.5 mpg over what I was getting previously. Plus it also smoothed out the idle a little bit. Worth it to me.
Good luck!
Old Nov 27, 2016 | 10:11 PM
ExcursionXLTjordan
Well done! Thank you Project and DSN46 it was a fruitful information about this DIY.
Old Nov 28, 2016 | 05:31 AM
projectSHO89
BTW, a faulty CKP sensor would cause a "crank, not fire" symptom, one on numerous possibilities for that symptom.
I see no way for a CKP sensor to cause those symptoms. If that sensor malfunctions, the engine either doesn't run at all or it runs poorly enough to set a fault code.
Old Nov 28, 2016 | 07:18 AM
DSN46's Avatar
DSN46
I had my doubts also. But it is what it is, unless somehow I'm lying about it all.
James
Old Nov 28, 2016 | 03:17 PM
projectSHO89
There are alternative explanations that do no include include intentional mis-stating of facts.
tfunk88
Jul 23, 2019 09:13 PM
Balanceman
2009 - 2014 F150
Aug 27, 2017 08:16 AM
jimbo beam
Dec 12, 2009 05:17 AM
TommyR
Modular V10 (6.8l)
Feb 4, 2009 07:18 PM
eallanboggs
Apr 17, 2008 09:17 AM
