Sponsored by: Auxito
Crankshaft Position Sensor
Old Jan 17, 2011 | 04:10 PM
michelle85's Avatar
michelle85
Red face Crankshaft Position Sensor
Hello Guys....
My name is Michelle and I sure can use some help. I am trying to change the Crankshaft Position Sensor on a 2002 F150 V8. I cant seem to find it....I was told it was behind the Starter then behind the A/C Compressor...Whitch is it and If behind the compressor How do I get it off? Any thoughts and help would be greatly appriciated.
Michelle
Old Jan 18, 2011 | 03:19 AM
Bluegrass 7's Avatar
Bluegrass 7
It is behind the front crank pulley and A/C compressor.
Get under and take a look at the situation and see what has to come off to get at it.
You will see a cable that plugs onto the sensor.
Be sure you need to replace it first.
Good luck.
Old Jan 18, 2011 | 09:46 AM
Johnny Langton's Avatar
Johnny Langton
Like Bluegrass said, it's behind the A/C compressor-located on the side of the timing cover. The AC compressor must be at the very least, lowered down to allow you to remove the old sensor and install the new one.
JL
e250blex
Apr 8, 2015 07:21 PM
jmh944911
Mar 13, 2014 12:40 PM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
Alanok
1983 - 2012 Ranger & B-Series
Apr 11, 2005 11:16 AM
msanders
Feb 25, 2005 03:26 PM
