A/C Compressor Removal?
Old Jun 5, 2012 | 10:40 PM
snorindad's Avatar
snorindad
Does anybody know how many bolts hold the a/c compressor on? I removed the front two and it is hard to tell but I think I can see one or two more thru the frame but I am not sure. Do not want to remove a bolt that does not have to be especially thru a hole in the frame where it would be hard to install. Thanks
Old Jun 5, 2012 | 11:48 PM
snorindad's Avatar
snorindad
Got it there was just one more bolt but a PITA to get to!!
Old Jun 5, 2012 | 11:58 PM
KRDiesel's Avatar
KRDiesel
NOTE: Installation of a new suction accumulator is not required when repairing the air conditioning system except when there is physical evidence of system contamination from a failed A/C compressor or damage to the suction accumulator.
All vehicles
Remove the drive belt from the A/C compressor pulley.
6.0L diesel vehicles
Remove the transmission cooler filter assembly. For additional information, refer to Section 307-02 .
4x2 vehicles
Remove the RH fender splash shield. For additional information, refer to Section 501-02 .
Loosen the bolt and detach the compressor manifold and tube from the A/C compressor.
All vehicles
Raise the vehicle.
4x4 vehicles
Remove the RH front wheel and tire.
Loosen the bolt and detach the A/C manifold and tube assembly from the A/C compressor.
5.4L and 6.8L vehicles
Disconnect the wire harness connector from the crankshaft position sensor.
All vehicles
Disconnect the wire harness connector from the A/C clutch field coil.
NOTE: The lower rear bolt must be removed with the A/C compressor.
Remove the bolts and the A/C compressor.
Old Jun 6, 2012 | 09:14 AM
snorindad's Avatar
snorindad
Thanks for the Info
Old Jul 23, 2019 | 02:04 PM
Bruin008's Avatar
Bruin008
All vehicles
4x2 vehicles
All vehicles
Raise the vehicle.
4x4 vehicles
All vehicles
OOOOOH How I wish it was that easy hahaha. I have tried twice now and unsuccessful both times. I think my next step will be to raise the engine. I already purchased all the parts, compressor, condenser, evaporator, etc, otherwise I would have brought it to a shop by now.....oh and because they want my entire check plus the next 5 to change the compressor.
Old Jul 23, 2019 | 08:27 PM
john shopes's Avatar
john shopes
Ratcheting box wrenches are your friend for that rear bolt. I just did mine in my 03. I also replaced everything else while i was in there. The compressor is a real bitch to get out of there, especially the rear bolt. It might be worth taking the fan shroud out to get a little more room.
jon705
Feb 4, 2013 06:43 AM
brfan
May 10, 2010 09:31 PM
bob1987f
Oct 7, 2007 11:04 PM
bhocart
Jun 5, 2007 07:51 PM
Sturge
Aug 16, 2005 11:29 AM
