eot mod
Old Apr 13, 2008 | 01:07 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
eot mod
did the oil temp mod last night but the roads were wet so i couldnt drive it to see if it made a difference i used a 4.7k as well
Old Apr 14, 2008 | 07:41 PM
c00nhunterjoe's Avatar
c00nhunterjoe
find some dry roads, you will be happy with it
Old Apr 14, 2008 | 08:30 PM
bigbadwolfe's Avatar
bigbadwolfe
how is this mod done
Old Apr 14, 2008 | 08:32 PM
jimwilsonmasonry
i switched to a 5.6k resistor and im not sure if i can tell much of a difference maybe a lil but probably my mind playin tricks on me -will a 5.6k resistor hurt anything on the eot mod
jimwilsonmasonry
basically same method as c00ns 10k mod but on the eot sensor
Old Apr 14, 2008 | 09:01 PM
jimwilsonmasonry
oh coon i like the mod but i did it the day after i modded my idm to 140 volts that i got a very nice power increase out of both of them it seems like my truck has doubled in power from when i first got it, the cat was clogged ,and first gear was nothin , now i can squeel tires with 355 rear end easily with them few easy and cheap mods i cant wait to get injectors and chip
Old Apr 14, 2008 | 09:03 PM
BlueMule's Avatar
BlueMule
The EOT mods works ok with a 5 speed but be careful with an auto. It not only changes the fuel delivery and timing but it'll keep the torque convertor from locking. Pay attention to your ATF temp gauge and/or install a TC lock light so you can see how long the lockup is delayed.
Old Apr 14, 2008 | 09:12 PM
jimwilsonmasonry
thanks for the info bluemule i think im gonna go back to my smaller resistor then
Old Apr 14, 2008 | 09:24 PM
c00nhunterjoe
i have had no change in torque converter operation. none at all... i stilll have the ngs so i will get static displays of the eot before and imediatly after to show the difference in temp the resistor makes
Old Apr 14, 2008 | 11:07 PM
IDMooseMan's Avatar
IDMooseMan
Looking forward to that, Joe.
Old Apr 15, 2008 | 12:38 AM
jimwilsonmasonry
so is it alright to use the 5.6k resistor
crazer42
18
Aug 7, 2021 12:26 AM
Pele
Jan 28, 2016 02:22 PM
rayezra
Oct 25, 2009 06:24 AM
tndiesel
20
Mar 11, 2009 03:24 PM
Rockwell
Jan 3, 2003 09:16 PM
