Back pressure control valve - waste gate?
Old Apr 11, 2008 | 09:26 PM
raydav's Avatar
raydav
I have a 2001 PSD. Is the thing Ford calls a back pressure control valve, what most of call a waste gate?
Ray
Old Apr 11, 2008 | 09:31 PM
Pocket's Avatar
Pocket
Nope. Our trucks have both a wastegate on the turbo, and an exhaust backpressure valve that sits between the turbo and exhaust downpipe.
The wastegate releases excessive exhaust at higher boost levels. The actuator is what sits on top of the turbo and has a red tube connected to it.
The exhaust backpressure is designed to aid the engine warmup in cold weather. The valve will close under low rpm low load conditions. The actuator for the exhaust backpressure valve is located underneath the turbo inside the turbo pedistal. You can barely see the rod sticking out underneath the passenger's side of the turbo.
Old Apr 14, 2008 | 10:32 AM
raydav's Avatar
raydav
That was my understanding. We just had a home show in town. Included was a diesel modification dealer; 20 years banks dealer, hot rod diesel puckup, yada, yada. I asked him about the back pressure control valve. He said there was no such thing. That that was really the waste gate. He was a real blow hard.
My ultimate question was/is, why increase exhaust system capacity if the engine control system is just going to create back pressure anyway. Unless maybe it is only active during warm up. Is it always wide open after that?
Old Apr 14, 2008 | 03:29 PM
Pocket's Avatar
Pocket
The exhaust backpressure valve is only activated during warmup. It's sole purpose is to help the engine warm up faster by creating an artificial load. The parameters are designed so that it opens when the engine oil temp reaches a certain level, and/or there is a certain amount of load placed on the engine based on exhaust backpressure and throttle position. The EBPV can also be modified to be used as an exhaust brake, just like the Jake brakes you see on commerical trucks.
Realistically you don't want any additional backpressure after the turbo. Some people elect to remove the exhaust backpressure valve based in part on that reasoning. I removed mine, but didn't see any real increase in performance. My EBPV was malfunctioning due to a clogged sensor, so it was staying closed and never opening until the engine warmed up. That was annoying, and I got tired of cleaning the sensor tube.
Not the first time a Banks rep didn't know the facts.
markiemark
6.7L Power Stroke Diesel
May 26, 2012 07:16 AM
scottie2hottie
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
18
Feb 9, 2012 09:13 AM
gumper 123
Jul 31, 2011 10:06 PM
dyhrdford
Mar 13, 2009 02:36 PM
t.j.g.
Apr 26, 2005 04:14 PM
