Covered under warranty
Old May 24, 2012 | 02:07 PM
markiemark's Avatar
markiemark
Just a heads up for my fellow FTE'S. Shut off the 2011 6.7 XLT and about 15 or 20 seconds later heard some clicking and then a loud humming/buzzing coming from engine compartment and it would last for approximately 1 minute. Had to take her in for the NOX sensor recall and an oil change anyway. Advisor called me back and said that the "waste gate solenoid valve" needed replacing. Only 400 miles until bumper to bumper expires. Did not ask if this would have been covered under warranty after 36,000. However, no waste gate solenoid is available and waiting for one to arrive. Tech said it was ok to continue driving in any manner. Good thing since I hook up the 5er tomorrow and headed to Durhamtown for Memorial weekend four wheelin and dirtbiking. Everyone have a great weekend and be safe!!!!
Old May 24, 2012 | 02:10 PM
jack_pine's Avatar
jack_pine
I had a similar situation with my 6.0 with another part. Since it was in their system before the expiration it was no problem. Would think that would apply here as well.
Old May 24, 2012 | 08:45 PM
slowmans's Avatar
slowmans
as long as a ticket is made with the mileage of the problem it doesn't matter if you go out of warranty waiting on parts.
Old May 24, 2012 | 08:54 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
sounds like you wont have any turbo until you get it fixed
Biggziff's Avatar
Biggziff
Probably an emissions component so maybe you'd be covered till 100K?
Old May 24, 2012 | 08:56 PM
Tuxedo Scorpion
waste gate is a turbo "vent valve"
Old May 24, 2012 | 08:58 PM
markiemark's Avatar
markiemark
Negative Tuxedo, turbo doing fine. The only effect that I see is the noise. Tech said its just releasing pressure.
Old May 24, 2012 | 09:06 PM
Biggziff's Avatar
Biggziff
It vents unprocessed exhaust, no?
Old May 24, 2012 | 09:36 PM
Tuxedo Scorpion
Wastegate - Wikipedia, the free encyclopedia
Old May 24, 2012 | 09:55 PM
Biggziff's Avatar
Biggziff
Compressor side. Duh. You'd think I'd know that having built a twin turbo Mustang.
Old May 25, 2012 | 08:19 AM
darren32's Avatar
darren32
Mine has been doing that for a long time (a year maybe??) and I have not noticed any ill effects. I am not sure if I will even get it fixed......
And I like the "what the hell is that" I get from people. I would not worry about it.
I still make 35 - 36 PSI boost!!!!
Have a great LONG weekend!
Mine was LAST weekend
Thanks
Old May 25, 2012 | 11:30 AM
Davgt500's Avatar
Davgt500
Mine has also done this for over a year. I have had no problems though, I just haven't fixed it yet. Probably should though!
Old May 25, 2012 | 10:45 PM
kper05's Avatar
kper05
Same noise here, too.
I always noticed it was from the turbo area so this makes sense.
I'll mention this when I take mine in for the NOx sensor recall.
Noise begins at 0:30 in the video.
This is with the key in the ignition but in the off position.
2011 F-250 6.7L PowerStroke noise - YouTube
Old May 26, 2012 | 07:14 AM
Fulltimer50's Avatar
Fulltimer50
How much pressure can there be with the engine not running? Sounds bogus to me.
Old May 26, 2012 | 07:16 AM
Tuxedo Scorpion
the pressure would match the outside ambient pressure
Ginther
6.7L Power Stroke Diesel
27
Aug 28, 2019 07:13 AM
bigjr2
6.4L Power Stroke Diesel
16
Mar 19, 2011 11:00 AM
FloridaF250
May 9, 2008 08:17 AM
seelyef150
2004 - 2008 F150
Feb 4, 2007 11:16 PM
Scotter06
General Diesel Discussion
Feb 15, 2006 09:11 PM
