waste gate adjustment
Old Jul 29, 2011 | 05:03 PM
gumper 123's Avatar
gumper 123
when adjusting waste gate i suppose you are to back off the jam nut and disconect rod to waste gate the screw it in to up boost or out to lose boost is this corect.
Old Jul 29, 2011 | 05:17 PM
snaponprofile's Avatar
snaponprofile
Take the whole waste gate off, then put one end in a vise and shorten the rod by threading it in. Do not let the shaft turn inside the top, bad things will happen. You got it shorter rod=more boost.
Old Jul 30, 2011 | 10:10 AM
Coalroller's Avatar
Coalroller
snapon is right your best and safest bet is to remove the waste gate and clamp one end in a vice and use the correct size wrench or a good pair of vice grips and even some penetrating lube to help... if the waste gate rod wont shorten or its very hard to turn do not force it! you dont want to break anything!
Good luck
Old Jul 30, 2011 | 11:21 PM
Aune163rd's Avatar
Aune163rd
what happens when you break a wastegate?
Old Jul 30, 2011 | 11:49 PM
hairyboxnoogle's Avatar
hairyboxnoogle
No waste gate means no way to bleed off extra boost, overboosting makes expensive things go boom.
Old Jul 31, 2011 | 12:16 AM
Aune163rd's Avatar
Aune163rd
AH, that would make sense, knowing my luck I would probably break something XD.
Old Jul 31, 2011 | 10:06 PM
GHeTTo JOe's Avatar
GHeTTo JOe
if you twist the rod and rip the diaphragm inside wont that allow your boost to leak out resulting in less boost?
microdevil45
31
Dec 4, 2011 06:33 PM
Sycostang67
26
Sep 22, 2011 02:03 PM
deerslayer165
Dec 19, 2010 11:32 PM
562dragnhra
Jan 2, 2010 04:40 AM
jsmahan
Aug 2, 2006 09:19 AM
