Code reader/scanner for 95?
Old Apr 9, 2008 | 10:33 AM
MagKarl's Avatar
MagKarl
Question Code reader/scanner for 95?
I'm interested in getting some sort of code reader or scanner. I was thinking AE, but then I read about the scan guages and that seemed like a less expensive route since AE also requires a laptop. My new concern is that my 95 may not be compatible with either AE or the scan guages. I've read that you can get the PCM reflashed to a newer version and then the scanners will work. Anyone done this? Are there any alternatives to AE or scan guages that would work for my rig?
Old Apr 9, 2008 | 11:05 AM
884x4broncoII's Avatar
884x4broncoII
i know there was a change in the data ports between 95-96 96 and newer is obII id immagin the whole pcm would need to be changed out as well as the data port connector, unless its differnt for the desiles
Old Apr 9, 2008 | 02:20 PM
bnine's Avatar
bnine
I use my superchip programmer as a code reader now on my 95.
Nice Work Truck
Jan 18, 2013 04:42 AM
rjmjr78
Arkansas Chapter
Oct 20, 2011 04:44 AM
crzycrazycarl
Nov 4, 2010 04:53 PM
rjmjr78
45
Mar 8, 2009 10:01 AM
WuShock
May 2, 2007 09:00 AM
