AE and 95' Ford Explorer
Old May 1, 2007 | 12:36 PM
WuShock's Avatar
WuShock
Is this vehicle to old to be used with AE and OBDII stuff? I can not get it to connect, and I am thinking the cut off date is right around in there somewhere? If it is too old, what are my options with other types of code scanning software?
Old May 1, 2007 | 02:53 PM
mrshorty's Avatar
mrshorty
1996was the first year OBD-2 was required. Rumor has it that a few models over all manufacturers got OBD-2 before then. The vast majority of '95 Explorers are EEC-IV/OBD-1 (The OBD-2 port under the steering wheel, if present, is inactive). The EEC-IV self-test connectors are under the hood, driver's side fender, I believe.
If you can count flashes of the check engine light, a paper clip is all that is required to get codes. Ken00 has an article with instructions in his tech info post at the top of the BII and Ranger forums. You could also put Ford EEC-IV self-test into your favorite search engine and you'll find several pages. Any self-respecting repair manual will also have the test protocol.
Old May 1, 2007 | 03:18 PM
WuShock's Avatar
WuShock
thanks for the reply. It is a 95' and there is an OBD port down below. Guess I will quit plugging it in if the stupid thing is inactive LOL.
Off to do some more searching...
Old May 2, 2007 | 09:00 AM
marragtop's Avatar
marragtop
As Mrshorty said, there is an EECIV connector under the hood that you can use if you have the correct tester.
Steelheader87
Mar 11, 2014 05:33 PM
sand_fiend
Jan 4, 2013 01:04 PM
forumsearcher
May 31, 2012 07:04 AM
REDBUD
Jul 23, 2010 09:53 AM
REDBUD
Jul 22, 2010 08:28 PM
