Code reader doesn't work?
Old Nov 3, 2010 | 08:41 AM
crzycrazycarl's Avatar
crzycrazycarl
I went to read my codes with a buddys scanner and an error came up. Is this because the reader is only for gassers? I tried to use by dads sct tuner as a reader as well and it just goes into a tuning mode, no check engine scan.
Old Nov 3, 2010 | 10:36 AM
kawa's Avatar
kawa
Talking
Need more info Carl. What scanners are you using? What was the error code? Gasser models will not work on our diesels, in fact, I think some diesel scanners won't work on our diesels.
Rog
Old Nov 3, 2010 | 10:38 AM
RRranch's Avatar
RRranch
If you have a pcm from a 94 in it then none of them will work. Just throwing that out there in case you got a junk yard pcm at some point.
Old Nov 3, 2010 | 06:16 PM
crzycrazycarl
I tried one of my friend's which was a cheaper walmart one and it said error in linking, and then tonight i went and borrowed advance auto's one (not sure of the brand) and that one said the same thing
Old Nov 3, 2010 | 06:57 PM
fordpride's Avatar
fordpride
Check the fuse for cig lighter if it's blow no scaner will work
Old Nov 3, 2010 | 09:02 PM
crzycrazycarl
Fuses are good, could the ts chip have something to do with it?
Old Nov 3, 2010 | 09:42 PM
kawa's Avatar
kawa
Talking
I suggest that you find a reader that is known to work on our DIESELS. Your OBD port could be corrupt, you've already stated that the power supply is good...............I'm still leaning towards the code reader.
Rog
Old Nov 4, 2010 | 12:26 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
You will need to use one like an AutoEnginuity or Snap-On as the codes are proprietary to Ford.
Old Nov 4, 2010 | 04:53 PM
crzycrazycarl
I tried using a snapon scanner today, while scanning for codes the scanner stuck on the screen "scanning for codes, if this lasts more than 60 seconds refer to appendex b"
command37
Feb 22, 2016 08:35 PM
captinphill
1978 - 1996 Big Bronco
Dec 15, 2015 02:26 PM
steveamann
13
May 5, 2013 03:33 PM
raptor2005
Feb 15, 2010 03:03 PM
KCMAGERS
May 8, 2007 12:36 AM
