ICP Sensor
Old Jul 31, 2010 | 03:31 PM
cputnam's Avatar
cputnam
Exclamation can u send to my e-mail cputnam123@hotmail
i can not get the photos or go to the links
Originally Posted by ozx3+1
Yes
Injection Control Pressure (ICP) Sensor <SUP> Printable View (240 KB)</SUP>
Removal
All vehicles
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-01.
Vehicles with automatic transmission
  1. Remove the transmission fluid level indicator.
  1. Remove the retaining nut and disconnect the transmission fluid fill tube from the stub tube and position it aside.
All vehicles
  1. Raise the vehicle.
  1. Remove the bolts and the turbocharger heat shield.
  1. NOTE: It will be necessary to position the heat wrap aside.
    Disconnect the injection control pressure (ICP) sensor electrical connector.
  1. NOTE: Use a 1-1/16 inch 12 pt. deep flare nut crowfoot wrench, such as a Snap-On® AN850817B, GAN850817B or equivalent, to remove the sensor.
    Remove the ICP sensor.
Installation
All vehicles
  1. NOTE: Verify the ICP sensor has the O-ring in place.
    Install the ICP sensor.
  1. Connect the ICP electrical connector.
    • Position the heat wrap back over the electrical connector.
  1. NOTE: Engine removed for clarity.
    Install the turbocharger heat shield and bolts.
  1. Partially lower the vehicle. Working from outside the right wheel area, engage the transmission fluid fill tube to the stub tube.
  1. Lower the hoist.
  1. Install the fluid fill tube retainer nut.
  1. Install the transmission fluid level indicator.
Old Jul 31, 2010 | 03:36 PM
bismic's Avatar
bismic
Ford restricted access to their site. You can not get the links.
p.s. - do you know how old this thread is?
If you are sure that your ICP sensor needs to be changed (and that it is a 2003 or an early 2004), then here are two threads (from the Tech Folder) that should be what you need:
https://www.ford-trucks.com/forums/8...with-6-0l.html
https://www.ford-trucks.com/forums/8...ml#post7693493
randypcourville
Jan 23, 2017 08:20 AM
USMCveteran
Nov 18, 2013 12:22 AM
sitInHigh
Sep 6, 2013 11:49 PM
dvldog13
Aug 6, 2013 12:24 PM
alexisvfd
Sep 27, 2012 06:56 PM
