icp sensor....where at
Old Sep 27, 2012 | 05:17 PM
alexisvfd's Avatar
alexisvfd
where is my icp sensor...cant find it on back side of the motor
Old Sep 27, 2012 | 05:19 PM
Snuggyworm's Avatar
Snuggyworm
what year is ur truck? if it aint in the back of ur truck, and u can locate it by the pigtail harness thingey, then ur truck is probably a newer model, and it will be on the passenger side of the engine closer towards the front and right next to the glow plug harness on passenger side.
Old Sep 27, 2012 | 05:23 PM
alexisvfd's Avatar
alexisvfd
its a 04/04......theres a sensor on the pass side valve cover up front that has a silver looking nut on the botttom of it..is that it
Old Sep 27, 2012 | 05:44 PM
alexisvfd's Avatar
alexisvfd
wheres my icp sensor at...04 6.0 made in 04/04
i think its on the left valve cover up front but aint sure
Old Sep 27, 2012 | 05:45 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Green circle on the left is the appx location
(no it's not puking, and yes the heater vac line is unplugged)
Old Sep 27, 2012 | 05:49 PM
Snuggyworm's Avatar
Snuggyworm
bryan beat me to it. yep, its tat general location. there will be some sort of brown color rubber piece encasing it. tats it. of cos, it'll have a wire harness plugged into it. also, the glow plug relay module looks like a silver heat sink looking rectangular box. it's next to ur icp sensor.
Old Sep 27, 2012 | 06:00 PM
alexisvfd's Avatar
alexisvfd
this plug is on the left side valve cover up front and has a indintion of a circle on the valve cover around it..is that the icp sensor
Old Sep 27, 2012 | 06:04 PM
Mich6.0's Avatar
Mich6.0
either on the passenger valve cover for later 6.0 and early are at the bottom of the turbo I believe, it is at the base of the TURBO ,HPOP cover area. I'm sure cheezit will be on later or someone else
Old Sep 27, 2012 | 06:08 PM
alexisvfd's Avatar
alexisvfd
theres a sensor on the pass side up front with a circle indintion in the valve cover...is that it
Old Sep 27, 2012 | 06:13 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Yes, that is it.
You can go to my albums and look in the miscellaneous album and you will find a picture of it. Center bottom of photo.
Old Sep 27, 2012 | 06:16 PM
alexisvfd's Avatar
alexisvfd
ok thanks ill try that by volt meters
Old Sep 27, 2012 | 06:30 PM
Snuggyworm's Avatar
Snuggyworm
if u can post a pic, tat might help. there are a couple of round things and we dont wan u pulling out the wrong thing.
Old Sep 27, 2012 | 06:56 PM
amdriven2liv
Yes!!!!
The picture above with the green circle on the left is the ICP SENSOR.
crazer42
27
Aug 12, 2013 10:35 PM
harback
17
Dec 13, 2011 12:36 PM
TheBludgeon
Nov 22, 2011 06:18 PM
BOBSDIESEL
Jan 19, 2008 05:42 PM
Mustardhead
Apr 17, 2006 09:24 AM
