thanks ...........the reason i asked is that advanced sells an ICP 201 and ICP203............they look identical......exact....plug is the same.......everything......but the one is 20.00 more.....just asking........do they run on diffrent pressures?
thanks but I am not concerned with the availabity..........I would like to know .......what are the operating parameters of the sensor? is there a diffrence
I don't have an actual 03-04 PC-ED manual to compare to, but everything I've seen for gauge coding and diagnostics has pointed towards the ICP reference values in volts being the same in each year of the 6.0L. Meaning the two sensors are different shaped to fit different holes, but are functionally identical.
.24V KOEO, .85V hot idle, 1.05V 30mph, 1.21V 55mph. Or:
well then there is no diffrence, Beacuse the stupid kid @ advance here in Pa sold me a sensor for a 2004(ICP-201)..........I needed one for 2003(ICP-203).........screwed right in and works fine....and 20.00 someting cheaper.
