I thought since I was in there fixing some fuel leaks I would try a HPX mod. I checked the specs on some Unisource hydraulic line a friend stocked and found out it met all of the specs for this application so I had him make one up. The best part was that with all of the fittings it only cost $10. I did notice that it smoothed out the power from idle and up, but it feels like the truck isn't pulling as hard as it used to. Is this normal or is my mind playing tricks on me?
Justin
Here I only be aware of how the connections were made, because the pressure is very HIGH there and you dont want a oil mess under the hood.
DO NOT CRACK THE HIGH PRESSURE LINE! on a running truck it gets as high as 4000 psi, a loose fitting could easily blow out of the head and the oil at that pressure would cut you like butter. do not mess with it, these are self bleeding systems. just drive the truck, fords spec after an opened high pressure system is easy driving for 25 miles to bleed the air
Justin
Depending on how this works out for you, I'm willing to bet you and your friend are going to have to make up a bunch of these hoses and send them to the rest of us.
