Sponsored by: Innova
Porting current box
Old Apr 15, 2008 | 12:49 AM
  #31
Don S.'s Avatar
Don S.
You do realize the the Efficency Bandwidth Product (EBP) of that CVR12 is better suited for a sealed enclosure. Not saying it won't work, but that the driver is more suited for a sealed box.
With that said, I would need to know if the CVR is a 2003 or 2005 model line.
The only thing I see an issue with is going with a 4" x 13" round port give you a 8.8 db Gain at 53Hz which is a narly bump. Drop down to 30Hz and the Amplitude drops to a -2.8 DB. In 23 Hz you drop 11.6 DB and seeing I do not have any experiance with the ford cabin gain, this could really end up being a one note wonder setup.
Your going to most likely have better lower extension with the sealed box.
Old Apr 15, 2008 | 01:07 AM
  #32
bgalaxy67's Avatar
bgalaxy67
You might be right on the one note wonder.
The 250 is peaking at 33Hz then again at 55hz. My box was designed for 37hz but the cut through changed it a little. I've changed up the port when I reconed the subs. when I retest I will double check the resonate freq of the cabin.
Old Apr 15, 2008 | 12:04 PM
  #33
86F150302's Avatar
86F150302
Its the 2005 model.
Old Apr 15, 2008 | 07:09 PM
  #34
Don S.'s Avatar
Don S.
Originally Posted by 86F150302
Its the 2005 model.
I wenton the assumption that it was the 2005 model. And as I stated before after modeling the sub, I found the response to be rather peaky with porting, when you hit 53Hz you'll most likely notice it and notice a steep roll off afterwards. This may tend to make the response sound boomy, with a real dip in response below that. But seeing I really don't know the cabin gain and in vehicle response of the truck this may accentuate the response or exaggerate it.
Old Jul 22, 2008 | 05:14 AM
  #35
86F150302's Avatar
86F150302
ok finally got around to getting the 4" pvc. Going to put it in when its light out.
If I don't like the sound ill just make a new side for the box and keep it sealed.
Old Jul 23, 2008 | 04:49 AM
  #36
86F150302's Avatar
86F150302
Well got it all done yesterday and it was pretty easy. Around 30hz and under it lost alittle but above that its much louder. I like it.
Old Jul 25, 2008 | 08:13 AM
  #37
03_PSD's Avatar
03_PSD
cool, thanks for the update.
Old Jul 25, 2008 | 11:26 AM
  #38
bgalaxy67's Avatar
bgalaxy67
If your looking to gain a little more on the bottom end, You can make the port a little longer. Not much music choice in the super low end but some.
Old Jul 25, 2008 | 10:55 PM
  #39
86F150302's Avatar
86F150302
ok cool
Thanks
Old Jul 26, 2008 | 11:54 AM
  #40
ReAX's Avatar
ReAX
33hz is a good number if you have women in the cab with you.
Redneckfordf2502002
Modular V10 (6.8l)
60
Jun 18, 2015 07:28 AM
vugger
6.7L Power Stroke Diesel
26
Jun 9, 2013 01:52 PM
Longland
Oct 19, 2011 08:37 AM
TheBigBee
Feb 8, 2010 10:09 PM
86F150302
Feb 17, 2009 11:06 AM
