electronic ignition
Old Apr 3, 2008 | 01:30 PM
reifwj's Avatar
reifwj
electronic ignition
All,
Thanks for all the help. I'm still working on the plan for my truck and prioritizing. I'm now looking at ignitions. What are the power increases on a 390? I don't care about MPGs. I was told by my brother that i could get and extra 10 horses out of an electronic ignition. Is it a hard conversion or just a bolt on? What specifics should i look for when chosing an ignition system? And of course, which ones are the best? Thanks in advance
Old Apr 3, 2008 | 01:46 PM
Mike G's Avatar
Mike G
Power increases, perhaps compared to points ignitions, but not 10 HP. You can add a 1975 era Duraspark II distributor and brain box to your FE for about $100. If you want to convert your current points distributor to electronic, go with the Pertronix, again, for about $100.
--Mike
Old Apr 3, 2008 | 02:48 PM
Freightrain's Avatar
Freightrain
Ya, pretty much what Mike said.
It will start easier, idle better, run better, but I wouldn't hold out for any great power gains(or mileage). That is unless it's been running on 5 cyls to begin with.
Remember those Split Fire commercials? Everyone claimed how much better their vehicle ran after installation. Well if it was needing plugs anyway....ANYTHING would have made it run better. Of course they didn't TELL you that part.
Anymore I'd just pick the Pertronix. For the money and ease of install, it can't be beat. Adding a Duraspark is just way too much crap and not worth it(for the same money as Pert.)
Old Apr 3, 2008 | 03:53 PM
reifwj's Avatar
reifwj
What's the difference between those and something like MSD?
Old Apr 3, 2008 | 04:06 PM
Redmanbob's Avatar
Redmanbob
A lot of ****ing money, and more crap to do before you will be firing it up.
Old Apr 3, 2008 | 04:17 PM
Freightrain
Ya, you don't really need a MSD(multiple spark) unit. They work below 3000 rpm, after that they are just an electronic ignition. No real need to spend $200 for a box, then run it with points(or convert to electronic dizzy too). Cha ching.
Old Apr 4, 2008 | 01:10 AM
dgrant09's Avatar
dgrant09
We are in the wire clean-up / organizing part of the Duraspark install mentioned above. I have not timed it yet, but the truck used to hesitate when I stepped on it, that is gone!! Sweeeeet!!
Frankin2 had the schematics for the basic install, I had the schematic for my truck and then picked up the same for the 76'. The distributor, ignition box, and wire harness from a 76' FE for 150.00 (the place is a little pricey, but the only one around with it).
It was advised to get the ignition box with the Blue wire connector on it.
The main reason(s) we went this route vs. Pertronix or others was the availability of parts up here (if something goes south I can go to NAPA) and the complete price!
Old Apr 4, 2008 | 06:11 AM
jowilker's Avatar
jowilker
I was told that i could get and extra 10 horses out of an electronic ignition.
Man, I love it when I read that.
John
Old Apr 4, 2008 | 06:56 AM
reifwj's Avatar
reifwj
that's why i love this place! It separates fact from fiction
Old Apr 4, 2008 | 03:31 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Unless you're an idiot like me who plays on the hairy edge of drivable cams, high compression, too big of a carb, and pure laziness, in a 5600lbs '74 highboy
The MSD made a huge difference in low-end torque, and cold starting and driving, over the stock Duraspark setup I transplanted. That was with a stock-style MSD coil instead of the stock Duraspark coil, which are the same thing I think.
But for the original poster, no, an MSD doesn't make sense unless you already have a coughing/spitting cold-hating FE
denny7170
Nov 16, 2016 08:20 AM
Delp73
Nov 5, 2016 07:43 AM
olfordsnstone
Sep 19, 2005 02:15 PM
cpt_insano
Mar 28, 2002 12:16 AM
Kikker
Aug 17, 1999 06:46 PM
