C6 Interchangeability
Old Apr 2, 2008 | 04:44 PM
cfrives3's Avatar
cfrives3
I hve access to a C6 for little or nothing out of a mid 80's van. What I want to know is if I can remove the tailshaft housing and output shaft to put it in a 4x4. I have a C6 in a Bronco that I would trust about as far as I could throw it. I want to go get this tranny, take it to a shop for rebuild and shift kit install, then put it in the bronco. I don't think the current tranny will hold up very long with a new 408W stroker motor. Thanks.
Old Apr 2, 2008 | 05:57 PM
rclarke's Avatar
rclarke
The output shaft and extension housing must be changed. The output shaft is the last thing to come out of the case. That makes it an overhaul since it would be foolish to go that far without replacing at least seals and gaskets.
Old Apr 2, 2008 | 06:03 PM
rclarke's Avatar
rclarke
sorry, double post
Old Apr 2, 2008 | 06:09 PM
rclarke's Avatar
rclarke
I guess I hit the button 3 times.
Old Apr 2, 2008 | 07:40 PM
cfrives3's Avatar
cfrives3
Thank you. Do you think a stall converter would be necessary since I am putting a fresh stroker motor in?
Old Apr 3, 2008 | 08:07 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Every torque converter is a stall converter. They all have a stall speed. Do you mean a higher stall converter?
Old Apr 3, 2008 | 11:47 AM
cfrives3's Avatar
cfrives3
Yes, sorry. I do not know what the stock one is in an 86 Bronco though.
Old Apr 3, 2008 | 12:39 PM
Mark Kovalsky
To do it right you need the torque curve of the engine. Talk to the converter manufacturer to get a converter that matches the engine's torque curve.
chrono4
Offroad & 4x4
15
Aug 15, 2022 07:23 AM
2broncs
Aug 30, 2019 09:24 PM
cfrese101112
1978 - 1996 Big Bronco
Apr 27, 2015 06:12 PM
david00f150
May 28, 2010 10:01 PM
Bronco308
Nov 26, 2008 11:50 PM
