compatible transfer case
Old Oct 26, 2015 | 08:40 AM
2broncs's Avatar
2broncs
I own a 1979 Bronco with a 351M and C6 transmission. I have a 1994 F-150 4x4 with a 351W and an auto trans I would like to swap into the Bronco. Will the transfer cases interchange between the two? I wanted to use the transfer case in the Bronco but don't know if it will bolt up to the 94' tranny.
Old Oct 26, 2015 | 08:56 AM
Diesel_Brad's Avatar
Diesel_Brad
Pretty much any t-case from 97 and older ford will bolt right on
Old Oct 26, 2015 | 11:10 AM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Any of them will bolt on but since your 94 has an aluminum transfer case is an aluminum one you need to double check you 79 bronco has an aluminum one otherwise the shaft in the transmission is different.
Steel transfer cases (like NP205 and NP203) have a long out put shaft where as aluminum transfer cases (like BW1356 and BW1354) have a short out put shaft.
trust me I know I had to do lots of research before picking up my C6 transmission for my 88.
Trav
Old Oct 26, 2015 | 03:01 PM
Diesel_Brad
Lean something new everyday
Old Oct 26, 2015 | 03:22 PM
2broncs's Avatar
2broncs
Thanks for the input guys. I need all I can get. I was concerned about the out-put shaft on the 94' tranny not working with the old 79' transfer case.
Old Oct 26, 2015 | 03:47 PM
Willz74's Avatar
Willz74
I'm pretty sure it's magnesium
Old Jan 23, 2016 | 10:48 AM
Sam95's Avatar
Sam95
Transfer case swap
does anyone know if I can swap a transfer case from an F1 52 and Expedition both of them the same year same transmission and say motor however the expedition is all-wheel-drive four-wheel-drive and the F1 50 is too will drive four-wheel-drive can I swap these two without having troubles ?
Old Jan 23, 2016 | 02:59 PM
Nothing Special's Avatar
Nothing Special
What year? Expeditions didn't come out until after '96 (the newest half ton trucks this forum covers), so you're probably asking in the wrong place. Not that we mind others dropping by, but a lot of us don't pay much attention to the newer trucks so we won't be able to help much.
Old Aug 30, 2019 | 08:21 PM
Jman1's Avatar
Jman1
Hey man, have a 95 f150, 5L 5 speed, will that transfer case go in a 1990?
Trav
Hey man, will a 95 f150, 5L, 5 speed transfer case fit in a 1990 f150, 5.8, auto, both are short box extended cab?
Old Aug 30, 2019 | 09:24 PM
bbf385's Avatar
bbf385
Trav
I think you are wrong.
There are three output shaft lengths with 4x4 C6 transmissions, but if you use the adapter that comes with the trans the amount of spline shaft that goes into the transfer case is the same for all 3.
You can use the NP205 in place of the 1356 but you will need to notch the aluminium adapter for the shift rail on the Np205. Look at the face of the steel adapter the np205 mounts to and you will see the notch I'm taking about.
If going with the double cardan front shaft there may be clearance issues with the pan on the E4OD.
Also, the Bronco speedo is run off the transfer case and the 1994 case has no provision for the speedo gear. The 1356 will make your rear driveshaft extremely short and with its extra width I would measure to see if it fits the narrower frame of the bronco.
tnfarmer67
Offroad & 4x4
Apr 15, 2012 09:48 PM
Diamond Jim
Dec 18, 2005 02:36 PM
classicfordfreak
Dec 8, 2005 09:22 PM
whitety1000
May 4, 2005 03:48 PM
