1978 - 1996 Big Bronco
inline 6 bronco
Old Apr 23, 2015 | 02:03 PM
cfrese101112's Avatar
cfrese101112
inline 6 bronco
i have an 82 bronco with an inline 6 with a 4 speed hwy gear tranny and was wondering if anyone knew if a c6 or aod automatic would fit in place of the current tranny?
Old Apr 23, 2015 | 08:06 PM
autox65's Avatar
autox65
300/302/351W all use the same bellhousing pattern. Flywheel/flexplate is another story.
300 is internally balanced, and the rest are externally balanced, so the flywheel for a V8 will have a counterweight, the I6 flywheel won't. so yes a AOD or the later 4R70W electronic version of the aod with better gear ratios will fit
Check here for part numbers for the flexplate and some "info"
https://www.ford-trucks.com/forums/96...-flywheel.html
Try over on the ford six forum Im a member there as well but I dont know as much about the big six 240/300 but i can get you in touch with the guys there who know if you have any technical questions i know who to ask.
if you were talking the ford small i6 (144,170,200,250 or the australian ford 221 or crossflow 250) then I can be of assistance as i have run all of those at some point.
got a 200 right now in a 65 mustang with a rollerized c4 transmission good to 800hp with a mild stall. the head is a custom aluminum intake with plenum and rare two barrel vintage holley made for the austrlian 4.1l I6 with a gt35r tubro and im looking to get 835hp from it.
Old Apr 25, 2015 | 05:28 PM
greystreak92's Avatar
greystreak92
So,m you are wanting to get AWAY from the 4-speed in favor of an automatic? On earth why?
Old Apr 27, 2015 | 07:59 AM
AbandonedBronco's Avatar
AbandonedBronco
That highway 4 speed (The SROD I'm assuming) is a piece of junk, but I'd put an NP435 in its place. It'd be a direct swap and less of a hassle.
The NP435 is an absolute tank.
Secondly, the 300 + C6 is a very robust combo, but the C6 is a power suck, and the 300 would be very sluggish behind it.
Old Apr 27, 2015 | 06:12 PM
gatorfor88's Avatar
gatorfor88
You will never get 835 hp from a 200 6 with a 2 bbl. Dont matter how much boost you try.
ralphmb123
Jun 20, 2011 07:11 PM
fomocojake1
Jun 30, 2007 06:31 PM
bmonnig
Missouri Chapter
Mar 23, 2007 09:06 AM
1chewey1
23
Mar 8, 2005 09:22 PM
timpage
Apr 29, 2000 05:50 PM
