E303 cam
Old Oct 16, 2002 | 02:05 PM
BB's Avatar
BB
E303 cam
Hi guys, asking this for a friend. Will the Ford Motorsport E303 cam pass smog in a carbureted 5.0L? The cam has an E.O. # for fuel injected applications only. I think the rough idle will tip off the smog techs.
Thanks!
Barry
Old Oct 18, 2002 | 11:07 AM
MustangGT221's Avatar
MustangGT221
E303 cam
Old Oct 18, 2002 | 12:42 PM
bulabula's Avatar
bulabula
E303 cam
Probably not.
There are a few issues here. What year is your friends truck/car that he wants to install this cam in? And smog requirements vary state to state. Was it manufactured with EFI or carb? Cats installed? Does your state have visual inspection as well? If so, a 1988'ish and newer vehicle with a carb is a dead giveaway. Do they even smog check old vehicles, or carb'd vehicles? I haven't had a carb'd truck or car in years. I do like my Holley's in the boat though.
Did your friends vehicle pass the smog check with the current cam installed in it? W/carb? With Cats?
The E303 does have an EPA #, and I know of a few Mustangs easily passing the local smog check here in MD w/ the slightly lumpy idle E303, but the EFI/cats were still intact.
Tell him to give it a go. Worst thing to happen is that it fails and you take it home to "get it fixed". When I used to mess around with my Mustang years ago, I heard stories of guys who were running B303's pulling the spout and ensuring the engines were really warmed up when doing a smog check (simple tail pipe check) - and passing. But they were running EFI and cats. Cats help. I'm not sure if they would pass on today's roller-dyno smog checks.
If you're into swapping EFI/carbs/camshafts, ..... wait, no, we don't want you to join the ranks of the enviro-evil.
Try this question at the Mustang forum (www.corral.net).
Good luck.
Old Jan 16, 2007 | 08:55 AM
king_butt_head's Avatar
king_butt_head
Hi all <>first post<> sorry to bring up an old thread but i'm about to do the same thing to my 95 150 351 all stock, parts should be here by monday. I was just wondering how it worked out for ya
Old Jan 16, 2007 | 10:57 AM
Kemicalburns's Avatar
Kemicalburns
wrong cam to be using in a truck period. good luck
Old Jan 16, 2007 | 12:41 PM
Blurry94's Avatar
Blurry94
Water 5 has an E-303 cam in his truck; 94 F-150 5.8, 65mm single bore throttle body, GT-40 upper and lower intakes, RPM Perf. heads and a few other things. He did pass the sniffer test last time out with that cam and stock cats.
Old Jan 16, 2007 | 12:59 PM
P51D Mustang's Avatar
P51D Mustang
If the engine was originally carb'ed and it still has the original carb emissions stuff functional, I doubt the E303 will hurt it on the sniffer. Overlap usually helps emissions, that's why the E303 has tight LSA angles. It may be cleaner than the same motor with original cam.
The engine only has to meet the requirements that were set for it's year. If you install an engine older of older specification than the year of the vehicle, they will flunk it, even if it's correct for a carb'ed year, however.
Old Jan 16, 2007 | 01:44 PM
king_butt_head
I cross refernced the ford E303 to crane 444231 same came totally diffrent descripton ford said it is a low end cam crane said it's a screamer that need's the mod's that blurry stated. So i ended up calling the parts guy back and canceled the cam, i still have the roller setup comin. I'm really glad you said that kemicalburns thanks. I deff want a stump puller
Old Jan 18, 2007 | 11:32 AM
Kemicalburns
call compcam, tell them what you have , and let them know your running speed density as well. there are a few roller cams available that will work
billyrayf150
Feb 13, 2016 11:50 AM
nc73
Jan 3, 2016 08:48 AM
9.blake.6
26
Feb 23, 2015 03:58 PM
DarkGT
Nov 27, 2014 10:28 AM
traxx808
Aug 10, 2010 09:48 PM
