.......ford e303 cam.......
Old Aug 9, 2010 | 12:41 AM
traxx808's Avatar
traxx808
anybody know of a web site where i can look at ford e303 cams and other ford cams at other web sites...........thanks.............p.s. crank sprocket i got a 9 key way double roller. if i advance the sprocket 2 degrees will i feel a little more torque. my timing was bumped up to 16...........thanks...........
Old Aug 9, 2010 | 12:45 AM
86F150302's Avatar
86F150302
Summitracing..
Why ABC cams?
Old Aug 9, 2010 | 02:46 AM
traxx808's Avatar
traxx808
to 86f150302. i just want too see what cams are available before i make a decision. i don't want to get stuck with something i ain't gonna use.
Old Aug 9, 2010 | 03:04 AM
86F150302's Avatar
86F150302
Are you running MAF?
Old Aug 9, 2010 | 05:27 AM
lew52's Avatar
lew52
X-2 check summit out for cam specs , the E 303 is more of a mustang type cam but will work in a light truck , i use the E 303 with 1.72 RR but its in a very light 2wd reg cab SB , you need mass air & a custom tune or custom chip to make this cam work good ....Lew
Old Aug 9, 2010 | 07:44 AM
Conanski's Avatar
Conanski
And don't forget gears.. the truck will need a much lower than stock ratio.. Lew has 4.56's in his truck.
Old Aug 9, 2010 | 07:46 AM
nintey4f150's Avatar
nintey4f150
I have a trick flow stage 1 cam in my 94.. It's similar to the e303 but has better rpm range 2,000 to 5,500 so u don't really lose any torque
Old Aug 9, 2010 | 10:03 PM
traxx808's Avatar
traxx808
i do have maf and 3.90 gears. i am hoping with the maf i will have a better selection of cams than with sd. the cam r.p.m.s. will start at 1200-1500 and stop at 5000-5200. this is my daily driver and i want to have some fun from time to time. there are some people that say my truck is a dog so i want to give it some kick. any cams i should look at like isky, lunati, howards, comp cams. what are you guys using right now. hey nintey4f150 how do like that cam your using and what gears you runnin and you got a chip for that cam and lew52 how do you like that cam. do you have a chip or custom tune for your ride and conanski hows that cam runnin with your computer............thanks for the feed back guys.................
Old Aug 9, 2010 | 10:45 PM
nintey4f150
I love the cam i should mention I have a 351w and 4:10 gears and yes I have a chip for my truck as well.. I love the cam very good rpm range an sounds good
Old Aug 10, 2010 | 04:49 AM
lew52's Avatar
lew52
The E 303 works very good for me , custom burned chip ,
Old Aug 10, 2010 | 07:37 AM
Conanski's Avatar
Conanski
That is pretty close to the stock operating range so you will want to be conservative with the cam. The one I have works pretty good, the motor certainly makes a lot more power than stock but it's still quite weak below 3000rpm compared to my 5.8, if you really want impressive low rpm power you should be thinking about a 5.8 swap. For the 5.0 the Comp 35-320-8 is a better option IMO, it's the same as the 35-349-8 but with less lobe seperation so it makes more torque.
Old Aug 10, 2010 | 09:48 PM
traxx808's Avatar
traxx808
all right guys thanks for the info. it was very helpful to me. i just don't want 1 that will require a stall converter for the street............
Surfdaddy
Modular V10 (6.8l)
23
Feb 3, 2025 11:00 PM
billyrayf150
Feb 13, 2016 11:50 AM
YoGeorge
Modular V8 (4.6L, 5.4L)
Aug 27, 2008 11:02 AM
scott9320
Sep 19, 2003 11:36 PM
77_f250_460
Dec 13, 2002 07:34 PM
