Coolant
Old Mar 30, 2008 | 02:01 PM
novice psd's Avatar
novice psd
TSC tractor supply co.
Old Mar 30, 2008 | 02:32 PM
Neil64's Avatar
Neil64
Tsc
Thanks for the info.
Old Mar 31, 2008 | 02:24 PM
Neil64's Avatar
Neil64
Gold
I can not find any concentrated OAT antifreeze. Even if I get the mechanic to use the block drains, I got to believe I will never get a 50% mix using premixed coolant. If I switch to gold, is it already precharged with SCA? How often would I need to test gold?
Thanks..
Neil
Old Apr 4, 2008 | 02:22 AM
Neil64's Avatar
Neil64
Testing Gold Coolant
As I could not find any OAT/ELC concentrated for less than $30/gallon. Everyone is carrying 50/50 so they get to sell you twice as much and you are paying a huge preium for the deionize/distilled water. Therefore, I am going to switch from green to gold. How often does gold need to be tested for SCA? Are the same test strips used for both green and gold?
Thanks..
Neil
Old Apr 4, 2008 | 07:32 AM
Izzy351's Avatar
Izzy351
Gold is a Hybrid-OAT -- it doesn't need to be checked like green. It has some SCAs in it along with the OAT. You can test its pH every six months or year if you like, but I haven't bothered. Mine was replaced when I bought it due to the stat & temp sensor being replaced, so I know I'm good until put in the ELC.
Old Apr 4, 2008 | 09:29 AM
cgl's Avatar
cgl
My 02 came with Gold from the factory. The Zerez G-05 is pre-diluted while the Motorcraft Gold you get from the dealer is not. It was $11 for Zerex G-05 at Autozone and $9 for Motorcraft from the dealer... go figure I had to replace what I lost when I switched to the dual alternator upper hose and then again when my t-stat o-ring failed!
Old Apr 4, 2008 | 12:44 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Smile
You can get Shell Rotella ELC in concentrate form. Use THIS LINK to find a distributor.
Old Apr 4, 2008 | 06:29 PM
megawatt00's Avatar
megawatt00
TSC is tractor supply company
Old Apr 5, 2008 | 12:43 AM
Neil64's Avatar
Neil64
Thanks
Brendon,
That Shell link was very useful. I wish Shell had given it to me when I called them. I would have been able to find the Rotella ELC locally; albeit, for $25.00 - $30.00 a gallon for concentrate.
The shop working on my truck has already flushed and filled using gold. Knowing that, I have read posts that I should check PH levels every 6 months even with gold antifreeze. Has anyone had to add SCA before 3-5 years to gold?
Thanks..
Neil
tasilium
15
Mar 23, 2015 01:47 PM
68bluebeast
Mar 8, 2015 08:48 PM
scwirenut
91
Feb 26, 2007 10:17 AM
ordy1
Dec 22, 2006 08:38 PM
wildbyon
20
Jun 25, 2006 05:31 PM
