turbo will not seal
turbo will not seal
ok
Any suggestions on how to get the turbo and pedestal to seal. I have tried four time now and get a leak either on top or below the pedestal. I found out that the turbonetics turbo has a slightly larger drain hole than a stock. So it has to be dead on center with the o-ring.
I have no idea why the low side of the pedestal will not always seal. I clean everything well and pack the rings with vasoline. Gently put everything together and tighten evenly.
Has anyone made a gasket and done it that way?
Checked for warpage and the parts are true.
TN turbo has zip to do with the pedestal to engine seal. Still having a problem there?
As for the turbo to pedestal seal, might be a tightening sequence problem. Bolt the pedestal down, bolt turbo to pedestal, can be a bit tough but that is where most problems arise lining it up with the up pipe collector. Pry bars may help here to get things aligned. I had to R&R my GTP38R 3 times as the housing needed alignment, not the exhaust side but the impeller side. I finally got it indexed.
What torque are you tightening the bolts down to? And, are you doing it evenly in a sequence? When I do it, I'll start low, at like 10 lb-ft, go in a criss-cross pattern on the pedistal, then work my way up on torque in 3 even steps to the final torque. I also do the stepped sequence on the turbo and torque the turbo down before I tighten the collector clamp.
Also, where did you get the o-rings you're using? I've had good luck with stock ones from Ford, as well as o-rings from ITP and KCM.
