Coolant filter kit
Old Mar 14, 2008 | 07:16 PM
drakul20us's Avatar
drakul20us
Coolant filter kit
I've just finished with my new coolant filter kit. I got the base and 6 filters off ebay for just under $100. All the fittings and hoses cost me another $30 or so. I used a 4"x12"x 1/16" steel plate that's usually used for framing, I just bent it by hammering it, attached the filter, attached the plate to the radiator support bolt, and let the filter rest on the intercooler pipe. Probably not the best setup, but that's all I could think of. Besides, I dont' have the means of bending thick steel. The end result, I'd probably go with a complete kit from like dfuser.com, much less headache and cheaper.
Old Mar 14, 2008 | 08:08 PM
slowmans's Avatar
slowmans
I just did mine tonight I will post some pics tommorrow!
Old Mar 15, 2008 | 12:37 PM
slowmans's Avatar
slowmans
updated gallery, not bad for a home made job!
Old Mar 15, 2008 | 08:22 PM
elee3's Avatar
elee3
That looks good slowmans. How much $ do you have in it?
Old Mar 15, 2008 | 08:50 PM
slowmans's Avatar
slowmans
about 85 bucks total
Old Mar 16, 2008 | 10:07 AM
drakul20us's Avatar
drakul20us
looks nice, mine is a lot more crappier looking, with no shut off valves either. But, hey, it works.
Old Mar 16, 2008 | 01:42 PM
cartmanea's Avatar
cartmanea
slowmans, where'd you get your kit for $85?
Old Mar 16, 2008 | 02:15 PM
slowmans's Avatar
slowmans
I bought the base on ebay for 35 and got most of the other stuff at lowes, I got the aluminum for the bracket from work
Old Mar 16, 2008 | 08:01 PM
JJPMach1's Avatar
JJPMach1
I mounted mine on the rocker panel on the passenger side. There are lots of holes stamped into the sheet metal down there and it makes it very easy to mount it. The kit that I bought had a bracket that mounted to the radiator bolt in the same area that you are talking about. But the factory bracket there is plastic. I figured that that plastic piece would end up breaking over time. So it is mounted to the inside of the rocker panel, nice & solid and right next to my oilguard filter. I just needed about 20' of 3/8 hose.
Old Mar 16, 2008 | 08:35 PM
cartmanea's Avatar
cartmanea
The more hose you have inline the greater the flow resistance and the less flow you will get through the filter.
Old Mar 16, 2008 | 08:49 PM
JJPMach1's Avatar
JJPMach1
that's ok, I can deal with the loss of flow, not a broken plastic flange. I put my hand on the filter after a 10 mile drive, it was pretty hot, so it must be working.
hi-jacker
Oct 27, 2014 02:26 PM
MoreBoostPlease
Feb 4, 2010 05:38 PM
jack700
Jan 13, 2010 05:51 PM
live2wheel
Feb 4, 2009 04:40 PM
mjlevi
Oct 10, 2006 04:54 AM
