Decel tune, from DP ?
Old Mar 8, 2008 | 06:59 PM
powerstroke1869's Avatar
powerstroke1869
so bascically when you hit the tune it sounds exactly like your ebpv when your engine is still cold?
Old Mar 10, 2008 | 07:26 AM
IDPisan's Avatar
IDPisan
I don't know, maybe Dianne will be on today and answer some questions.
Old Mar 10, 2008 | 07:40 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
https://www.ford-trucks.com/forums/7...ght=decel+tune
post #75 in this thread...
Our website is getting ready to through a complete makeover. We will have infomation about this tune on the new site. This tune is a tune Jody will want to discuss with you. It's not a standard tune that will have a click down option on our site.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old May 4, 2008 | 08:41 PM
cangim's Avatar
cangim
Did anyone else get this tune that has any feed back on it? I am about ready to send by chip back and was thinking of getting two more tunes added to it. One would be a custom tow tune, the other would be a decel tune.
Old May 4, 2008 | 08:57 PM
HKusp's Avatar
HKusp
I have it. I got it at Smokin' a few weeks ago and I love it. I put it in position just below my 60T tune. I have used it loaded with the horse trailer and unloaded. If you have enough lead time to engage it, it works very well. It does take about 2 maybe 3 seconds for the ebpv to shut and then it sounds really good, but even before the ebpv engages, the torque converter locks and the defueling happens so it starts to decelerate the truck pretty quick. I haven't had a huge load, maybe 6-7K pounds at most. It works pretty good on that amount of load.
Old May 5, 2008 | 08:58 PM
Cracker 73's Avatar
Cracker 73
I got it from Dp awhile back and loved with 6 spd was great. I towed alot with it and it sounded great also. Make sure to get it loaded next to your tow tune. Well worth money!
Old May 5, 2008 | 09:00 PM
jdecker88's Avatar
jdecker88
Glad to see it worked well for you Jason, I was really impressed with it when you hit it just going down the hill empty. I am adding it on mine when I reflash it.
Old May 6, 2008 | 11:27 PM
cangim's Avatar
cangim
On the decel program did you get is setup to hold one gear, say like 3rd, or have it down shift through out. If down shift through out, how does everything behave? hold the tc locked the whole time while it down shifts, etc?
Old May 7, 2008 | 04:11 PM
sflem849's Avatar
sflem849
Mine is setup to downshift through the gears and then it stops all noticable function below 25 mph.
IT WORKS GREAT! To all who tow, get it. There is no reason not to.
To the morons who say, "I don't want to have to switch back and forth, I will do a switch for the ebpv." I say, you do know you have to do the tc lockup if you want it to actually work??? There is one more rigged up switch. In addition, you have to switch those switches (twice as many...) every time you want to stop. Finally, IIUC Jody can rig it up to decel every time you let off the fuel like a Jake brake. But if you think about it, you can turn a Jake brake on and off wouldn't you want to be able to turn it off...especially down a long grade???
One last thought. IIRC, the tune also changes tranny shifts and line pressures in addition to TC, EBPV, and defueling.
Old May 7, 2008 | 07:09 PM
cangim's Avatar
cangim
Sweet good to hear. I actually talked to Jody this morning about it. Sent my chip back today to get the new tunes loaded in. I went with the generic downshifting through the gears for the decel, as well as adding a modified 60 tow to lock the tc at 25mph under light throttle.
bobbyrjw
24
Jan 4, 2012 11:16 AM
kupaa
Aug 4, 2010 08:30 PM
overthehillbill
60
Jul 19, 2010 07:15 PM
RussB
Jun 30, 2008 11:26 PM
rivrrunner
Apr 14, 2008 04:12 PM
