DP decel tune !
Old Jun 28, 2008 | 10:01 PM
RussB's Avatar
RussB
DP decel tune !
Soooo I hit the decel tonight coming down a hill. (didn't feel like moving my foot to the brake) and I noticed the engine light came on while it was in decel and then went out when I switched it back out..... I haven't noticed this before, but it did it everytime tonight !
Does anyone that has the decel know if this is normal ?????? I would assume it is, but wanted to ask you guys !!
Thanks.. Russ
Old Jun 28, 2008 | 10:06 PM
HKusp's Avatar
HKusp
I have never had a warning light when using mine. Something is up.
Old Jun 28, 2008 | 10:12 PM
mueckster's Avatar
mueckster
Could be the EBP sensor throwing a code due to the EBPV closing and causing higher than normal back pressure. Have checked for codes? I have gotten one before for high back pressure during WOT acceleration.
Old Jun 28, 2008 | 10:33 PM
RussB's Avatar
RussB
Don't have a way of checking codes.... wish I did ! Do you think if my tube is clogged with soot the decel tune would work at all ??? I have never cleaned my tube before ! I need too ! The tune works great how it is and the light goes out right away !
Old Jun 28, 2008 | 10:38 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Nope mine doesnt throw a code.
Old Jun 28, 2008 | 10:46 PM
mueckster's Avatar
mueckster
I was thinking more in line with the EBPV not opening quick enough and causing the higher back pressure. Weak spring or oil pressure not bleeding off fast enough from behind the apply piston.
Old Jun 29, 2008 | 01:08 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
No code here but i think roland might be on the right track.
Old Jun 29, 2008 | 06:29 AM
jdecker88's Avatar
jdecker88
No codes here and I have left it on for some long steep grades.
Old Jun 29, 2008 | 10:19 AM
sflem849's Avatar
sflem849
No probs here either. I am with EBPV type issues.
Old Jun 29, 2008 | 07:17 PM
RussB's Avatar
RussB
Hey guys.. Just got home from fishin..... The truck was fine today.. no light when in decel.... It was kind of weird last night.... only saw the engine light on when it was in decel.. but I got on the throttle fairly good a few minutes before... Could this have something to do with it ???? Maybe ??? I don't think it's the fault of the decel tune itself !
Old Jun 30, 2008 | 12:32 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Coincidental most likely. I would have that code pulled just to be sure. It could be something unrelated. It could have nothig to do with the EBPV.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Jun 30, 2008 | 11:15 PM
RussB's Avatar
RussB
Diane
Thanks Diane... I will see if I can get someone to pull the code if it even stayed in there.. I haven't seen it since... So, I'm not overly concerned about it. Tell Jody I'm very happy with the tuner and thank him very much for the help !!!!!
Old Jun 30, 2008 | 11:26 PM
USAF CCM's Avatar
USAF CCM
Diane
: Jody & Diane, Thanks again for everything and glad you made it home safely! V/r Les
grec-o-face
Feb 19, 2014 04:14 AM
bobbyrjw
24
Jan 4, 2012 11:16 AM
TourqueRise
19
Aug 27, 2009 11:10 PM
aa767man
Apr 3, 2009 12:18 PM
IDPisan
24
May 7, 2008 07:09 PM
