does anyone fish anymore
Old Mar 17, 2008 | 12:40 AM
  #46
Secret Agent 069's Avatar
Secret Agent 069
Originally Posted by sierraben
Why you calling Dolly Vardon a fish. She's not a bad country singer.
I remember seeing tons of fishing boats near Campbell River and Nanaimo.
Never made it to Bella Coola, though.
Dolly Vardon
Dolly Parton
Both SMELL like fish, but only one is really edible.
Old Mar 17, 2008 | 08:00 AM
  #47
freirefishing's Avatar
freirefishing
23inch snook and 20 inch red on saturday, sunday i went to tarpon lake, threw the cast net a couple of times and had some shiners and shad to put out under some corks for large mouth, only cought 1 about 17 inches
Old Mar 19, 2008 | 02:23 PM
  #48
mikey92665's Avatar
mikey92665
way 2 go
sounds like a good day on the water,but anyday on the water is better than workin
Old Mar 19, 2008 | 04:58 PM
  #49
zx250's Avatar
zx250
Of the next Riffraff East
Naw, I don't fish much, well much more than 3 days a week.
Tools???
Results???
Hooked up one more time.
So, to answer your question. Yes I do and as often as I can.
Old Mar 20, 2008 | 06:44 PM
  #50
mikey92665's Avatar
mikey92665
Wow
maybe someday ill have me a front bumper to fish off of. that is a cool set-up,like the pics,those fish would b on the wall at my house.
Old Mar 20, 2008 | 06:52 PM
  #51
zx250's Avatar
zx250
Ah, but they all swam away to be caught again. The rod rack was my design and welded up by my buddy. That's a design 20 years in the making. Never really thought about fishing off the front bumper at the coast and the rear bumper on the lakes. LOL
Old Mar 20, 2008 | 08:40 PM
  #52
bcjim's Avatar
bcjim
The fuel costs are getting a bit silly. $800 fill ups are tough to swallow, and my boat isnt that big. Some my friends have 500 gallon tanks. It definitely affects how far and how fast I will go.
Old Mar 21, 2008 | 09:12 PM
  #53
mikey92665's Avatar
mikey92665
went 2day, the water was 2 muddy,nothin 2 speek of.if i said i caught a fish 2day i would have 2 b lying!
Old Mar 21, 2008 | 09:24 PM
  #54
dragogt's Avatar
dragogt
I got question for yall, I changed the line out on Zebco 733 to a 15/60lb test spider wire and now it wont cast.
is it just b/c its a spin cast reel or what? It did great before I changed it, but I wanted a stronger line for when I go to the lake.
any ideas or suggestions?
Old Mar 22, 2008 | 07:34 AM
  #55
mikey92665's Avatar
mikey92665
Thumbs up line re-spoolin
make sure that the line comes off your spool the same way it goes on your reel.this prevents line twist,also some reels when going 2 a larger line diam. u have 2 use less line. braid is funny , it works great sometimes it dont.hope this helped.
Old Mar 22, 2008 | 09:51 AM
  #56
dragogt's Avatar
dragogt
alright I'll try and re-spool today, and see if that helps thanks.
its funny though I didn't think the spider wire was any bigger than what I took off, it actually looks smaller, maybe it's the braid?
Old Mar 22, 2008 | 12:58 PM
  #57
mikey92665's Avatar
mikey92665
re spoolin
you got 2 remember.braid is stiff.mono is alot smoother.
Old Mar 24, 2008 | 12:09 PM
  #58
freirefishing
all i use is braid with longgggggggg leaders, you have to use it like fly line.....take a 15ft piece of mono, tie it on to your reel, connect the braid and mono and spool it up.
braid is very hard to start the spool with, its stiff like mentioned above, and doesnt grab the spool in the beginning. once the mono is on, then the braid will go on tight on the reel, and then problems like not casting are solved, along with other problems that will occur if you dont use this method.
trust me theres more fisherman,registerd boat owners here in fla than anywhwere in the us, i have lost probably well over 100 bucks on braid not knowing that simple stupid little rule......you might be able to get away with it on your larger reels, but not on smaller reels........now tie on a piece of leader and your good to go
Old Mar 28, 2008 | 10:28 AM
  #59
dragogt's Avatar
dragogt
tks for the advice, I switched out to some I think fly fishing line that I've had for years and that solved my problem. But next time I will defiantly try the mono method.
Old Mar 28, 2008 | 02:50 PM
  #60
sierraben's Avatar
sierraben
I never tie any type of line to my reel; only because if that fish takes all of your
line off of your reel, it could possibly pull your rod and reel out of your hand, and it's lost.
In my case, I'd rather lose a line $70 fly line, $15 backing, $5 leader, and a $5 fly,
than a $250 fly reel and a $500 fly rod.
