Pulling 6.9 out
Old Mar 4, 2008 | 04:39 PM
polarisman729's Avatar
polarisman729
Exclamation Pulling 6.9 out
Hey,
I'm working on pulling the 6.9L out of my 84 F250. I have everything unhooked and all of the engine to bellhousing bolts out. I tried hoisting it out and it only moves up and won't come forward. It acts like its still attached to the tranny. Any ideas?
Old Mar 4, 2008 | 06:50 PM
DT 466Man's Avatar
DT 466Man
sounds like the motor mount stud is still in the frame......and catching. i have had mine out enough to beable to pull the motor in about an hr.......the first time it happened like you described. i wasn't lifting it high enough to get it to pull forward.
DT
Old Mar 4, 2008 | 07:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Six bell housing to engine bolts.
Four motor mount bolts.
Exhaust pipes removed from the manifolds.
Old Mar 4, 2008 | 07:35 PM
buffalobob's Avatar
buffalobob
polarisman - if you have all the bolts out and engine high enough as described below - then you need to pry the engine and trans apart with prybars/screwdrivers .......if youre from oswego ny - that explains it - salt corrosion on the alignment pins between engine/trans.........just went thru what you are with '86 f-250 4x4 w/ 460.....a LITTLE heat in the pin area of bellhousing might help too.....good luck
Old Mar 4, 2008 | 08:05 PM
AndysFords's Avatar
AndysFords
Do you have the 4 bolts out between the tranny and bell or 6 out between bell and engine ?
Old Mar 4, 2008 | 09:19 PM
polarisman729
hmmm.....I can't remember if i pulled 6 bolts out of the bellhousing to engine mount.....I'm thinking I only got 4. Will look tomorrow. I will also check to see if the alignment pins are froze (may be my problem). Thanks guys.
1984F2506.9
Aug 19, 2014 08:21 AM
6.9idiatsturbo
May 14, 2012 10:14 PM
ColdForge
Jul 6, 2011 02:04 AM
Diesel_Brad
Nov 19, 2010 04:06 AM
buckshot76
Oct 5, 2004 08:32 PM
