ccv???
Old Mar 1, 2008 | 06:14 PM
ldfry001's Avatar
ldfry001
ccv???
i have a early 1999 f250 and my crankcase vent goes directly into the intake housing. in every picture that i have seem the tube vents out the back of the crank, so if i remove what i think is the vent i will have a hole in my intake tube. so i guess do i need to turn that cover around and plug the hole in the intake tube to do the ccv. my turbo tubes leading to the intercooler are leaking oil on the driveway.
Thanks
Lloyd
Old Mar 1, 2008 | 06:20 PM
c00nhunterjoe's Avatar
c00nhunterjoe
replace the whole plastic housing with a piece of 4 inch pipe.
Old Mar 1, 2008 | 07:00 PM
ldfry001's Avatar
ldfry001
ok that works thanks
Old Mar 1, 2008 | 07:08 PM
c00nhunterjoe
Thumbs up
no problem, anytime
Old Mar 1, 2008 | 08:03 PM
clintbonnie's Avatar
clintbonnie
Check around the muffler shops.. they should have a piece of 4" OD stainless steel. Make it the same length as the stock plastic tube.
Old Mar 2, 2008 | 09:41 AM
RobertJohn's Avatar
RobertJohn
Will 4 in. pvcwork as well ? I've got a lot laying around or does it have to be stainless ?
Old Mar 2, 2008 | 09:48 AM
Izzy351's Avatar
Izzy351
PVC is usually measured *ID*. What does fit is a 3" coupler which is 4" *OD*. But it is a bit more restrictive than the SS pipe. It does work though -- I've been running the PVC coupler for many months. Mine will get changed to SS shortly. I have a piece sitting here that I haven't gotten around to cutting to fit...
Old Mar 2, 2008 | 09:49 AM
PaysonPSD's Avatar
PaysonPSD
Others have used PVC. Should be just fine. I personally justed plugged the old CCV hole with a nylon insert and an epoxy mastic. Reusing that stock piece made for a perfect fit for the AIS intake.
Old Mar 2, 2008 | 09:50 AM
guitarpicr's Avatar
guitarpicr
It doesnt have to be stainless -A lot of the guys on here use pvc pipe. ID will be a little smaller than the ss pipe.
Old Mar 2, 2008 | 09:55 AM
RobertJohn's Avatar
RobertJohn
Thanks everyone...dang that was fast...
Old Mar 2, 2008 | 10:09 AM
mudmaker's Avatar
mudmaker
I found it easier just to put a rubber cap and hose clamp on the hole in the intake, instead using a piece of 4" tubing.
Old Mar 2, 2008 | 02:42 PM
machmedic's Avatar
machmedic
I also use the PVC coupling and works fine for now.
Old Mar 2, 2008 | 08:59 PM
superduty4x4's Avatar
superduty4x4
What size is the hose required to fit the CCV?
Old Mar 2, 2008 | 09:02 PM
PaysonPSD's Avatar
PaysonPSD
3/4" and if you are going to reverse the dog house be careful. There are to o-rings between it and the valve cover. They will most likely have to be replaced.
Old Mar 2, 2008 | 09:04 PM
superduty4x4
That's what I thought but thanks for confirming PaysonPSD.
Brian Uhlenhake
6.7L Power Stroke Diesel
86
Oct 22, 2023 03:04 PM
Lloyd399
18
Jul 10, 2017 05:49 PM
SpartanDieselTech
Apr 10, 2014 09:41 PM
smoky_diesel
19
Nov 5, 2007 03:11 PM
4X4 IN REFUGIO
Jun 20, 2005 10:25 PM
